1996 road king coil not firing on the back cylinder not getting fire to the back cylinder of the wiring plug that goes to coil
SOURCE: not runing
switch plug wires and see if the dead cylinder starts firing --if it does you need new wires
SOURCE: Rear cylinder not firing
The first thing I would do is replace the spark plugs again. You can foul a plug and it will cause you more problems than you can ever imagine. I see you have done all the logical things that I would recommend but I did not see you have replaced the plugs after the 200 miles. You would be surprised at how many times a $2.00 part can cause fits beyond belief.
SOURCE: no fire at the plugs, battery fine, was running
Your Sporty has a fuse box somewhere. check the fuses to see if any are blown. Harley always puts their ignition systems on their own circuit. If you don't find anything that way, contact me directly at [email protected] and I'll scan a trouble shooting chart in and send it to you. There's more to the late models than there was with the early models.
SOURCE: how do i test the coils on my 05 harley road king
1st chec for loose, corroded or bad wires-specially ones from the plugs and batt--coils can be tested at auto stores but remember thats no olschool hd-it has a computer n electron ign-secure urself a clymer service book
SOURCE: wiring diagram for tourpak on 2003 Harley Road King Ultra Classic
i have a 2003 ultra classic my riding lights keep blowing the fuse it wont do it sitting in the garage i have gone thru the wiring harnessing looking for the short fixed many things but still have the problem the turn signals work the brake lights still work so where do i look
