Question about Soyo DYLT032D 32 in. LCD Television
Took it apart and cannot find master shut off button so trying to find that or find another way to turn on.
SOURCE: Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card,
Lets first make sure your remote is not causing your problem,
Look at the light (led) on the remote, is it lit and pulsing?
If not you are having a problem with the control panel,
Have you recently cleaned your tv with a liquid?
If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 11, 2009
SOURCE: Soyo Tv keeps on turning self off.
Call your manufacturer if you are still under man. war. they can replace/repair the unit for you if not they can give you some referrals. Sounds like your powerboard is going to go out on the unit.
Posted on Aug 07, 2009
SOURCE: my soyo lcd tv is not turning on properly..It
Ur main video backlight board is dying or dead much be replaced.
Posted on Oct 22, 2009
SOURCE: My soyo shut off and won't come turn back on
It seems like the fuse has blown on the power board inside the tv, to get at it you will have to remove the back cover, the power board should have a fuse on it somwhere have a route around and you will find it, pop it out of the fuse holder and take it to your local electrical appliance store and they should be able to get one for you, they are only cheap.
Posted on Feb 05, 2010
SOURCE: Red power light flashes red
Power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 03, 2010
Apr 25, 2018 | Sharp Televison & Video
Feb 16, 2011 | Televison & Video
Nov 03, 2010 | Soyo Televison & Video
Jun 18, 2010 | Thomson LCDB 03B 27 in. Television
Mar 19, 2010 | InFocus User guide, LP500 / 530 Projector...
Jan 03, 2010 | NEC NP-1000 Projector
Oct 22, 2009 | Soyo DYLT032D 32 in. LCD Television
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Aug 26, 2009 | Microsoft Xbox® 360 Core System Console
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
