SOURCE: HDMI
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
SOURCE: no sound
you can't, you have to use the rca jacks for the audio they should be by the DVI connector.
SOURCE: THE MALE ADAPTER FOR FEMALE CABLE INPUT IS BROKE,
You can but you have a real problem---someone is going to have to unsolder and remove the tuner that the coax fitting is a part of--not real easy on this model----
Then to replace it you have to unsolder whatever is left of the old pin from its center that is soldered into the circuit board inside the tuner-----
There is a much easier way to deal with this---if you have cable, direct TV, sat, whatever----get a box that allows you to connect into one of the sets of audio and video jacks on the back of the set---you bypass the cable fitting and the tuner--you can even use a old vcr and it does not have to be able to play--just use it as a tuner and go into one of the video inputs---
Let me know if you have concerns or questions- I am here to help.
SD TECH
