Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the freezer open, if I depress the light switch the noise re-starts, stopping if I let the switch out.
Posted by jongreen8 on
Anonymous
  • 3 Answers
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Posted on Jan 13, 2010
Anonymous
I have a similar noise on my mbf2256keq bottom freezer. When the ice in the ice maker gets stuck it makes a wierd croaking noise as it tries to eject the ice. I open it up and push the ice out, then it stops, I dont' know how to stop it from happening though
Posted on Jun 27, 2009
GE Profile making knocking noises at different times
I have the GE profile Refrigerator with ice maker in the refrigerator compartment. Mine was knocking loudly for long periods of time, so I finally removed the icemaker by removing the side panel in the icemaker compartment held with 1 phillips head screw, disconnecting the electrical plug (unclip), pulling the tab of the icemaker down (on top) and sliding it toward the door, thus removing it. There was ice frozen in the motor compartment that was the problem. I let it thaw out and re-installed. All was OK after that..
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator sounds like frogs croaking
it may have a fan in the refrigerator at the back wall were you pull the draw out
Mar 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite Trio makes creaking/groaning sounds
Jan 30, 2009 | Jenn-Air JFC2089HE French Door...
Discovery croaking frog clock
I have the same problem about the frogs not croaking. Is there any place you can purchase a new clock? I love the clock and miss the frogs!
Dec 30, 2008 | Watches
Funny fridge noise, kenmore elite trio
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Trio 596.76502500 Mystery Noise
Does the noise only occur when the compressor is running ? My unit has this problem, similar symptoms to your unit, they stop when the freezer door is opened, etc., Several service calls have not completely eliminated it - yet ! The problem seems to be that the compressor coils are too close to each other and rattle. Adjusting them helps for a awhile.
Jul 31, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
4,537 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
