Most dryers stop heating due to a clogged vent or duct. Check your duct hose inside the house for lint/water clogs. You will have to remove it to do this. Then check the outside vent for lint clogs and make sure that its opening properly (louvered vents). If thats not the case, call up Sears and use your warranty.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
