Question about Lenovo Computers & Internet
Touchpad lock I have Y580 ideapad, my touchpad sometimes clocked top of right corner on the screen, and I can't do anything. because the mouse only let me have one touch, so I want to click or have a second touch, it's start from the top of right corner again. what is wrong?
Posted by Rose Mandly on
5 Related Answers
Anonymous
  • 63 Answers
SOURCE: "sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Posted on Nov 16, 2007
MysteryFCM
Steven Burn
  • 187 Answers
SOURCE: drifting cursor
Drifting of the mouse pointer is a well known occurance with laptops and is not something you can "fix" (occasionally you will be lucky and the manufacturer will release a patch, but this is very rare)
Posted on May 26, 2008
Anonymous
  • 125 Answers
SOURCE: acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Posted on Jul 30, 2009
Anonymous
  • 14 Answers
SOURCE: My touchpad right and left click button stopped working
is there a touch pad lock button, that locks the pad? if there isn't then there is most likely excess debris or dust or something under there that needs to be blown out with airisol can. If both of those solutions don't work then i would check to make sure the driver is installed for the touch pad. Good Luck. and i hope it works out.
RATE THIS SOLUTION
Posted on Aug 24, 2009
Anonymous
  • 11 Answers
SOURCE: left click button below touchpad on dv8000 not working
Friends,
Compaq Presario PC Notebook's main problem's are Audio Driver, Software Installation etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
Posted on Jul 22, 2010
When I plug in an external mouse, it won't click.
If an external mouse does not work correctly, you may need to install device drivers for it. Windows does not support all 'mice' just by plugging them in. Download and install the drivers for the mouse from the manufacturers web site. Do NOT do a factory recovery for a device driver problem.
Jun 29, 2014 | Lenovo IdeaPad Yoga 13
Sony Vaio laptop (PCG-61317L) once I start browsing the internet, the screen freezes and the mouse cursor disappears from screen. When I don't browse the internet, it sometimes does the same thing
The reason this is happening is that as you are typing; you're resting some weight on the thin plastic above the touchpad...which then makes contact and registers a 'click'; thus moving your cursor around. Or you're brushing your thumb against it when hitting the space key.
Some laptops are more susceptible to this than others. Some more modern laptops come with a button to turn the touchpad off to solve this very problem.
The only thing you can do about this is to disable the touchpad through the touchpad driver (down by the clock, usually) and use a mouse instead. Depending on how you use your laptop, this will be more or less inconvenient- if your laptop never leaves the desk; disable the touchpad and use a mouse...no problem. If you go mobile a lot, you'll have to enable and disable the touchpad all the time.
The other thing you can do is adapt your typing style so you don't put any weight on anything but the key you're pressing. This is quite difficult and uncomfortable, and is not recommended for long sessions.
Dec 01, 2012 | Sony VAIO VNCX1/B.CE Mouse
Aspire as3810TZ touchpad stopped working.
Press the mouse lock button. Most times you toggle the touchpad by a button at the top in the middle of the touchpad.
Some systems will have you to tap twice in the upper left hand corner of the touchpad to toggle the touchpad.
I've also seen some systems where you would have to Press and Hold the ALT or the FN key located at the lower left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
if all fails Click Start/Control Panel and look for mouse or touchpad. Go in and set the settings back to default.
You could try reinstalling the touchpad drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad rivers.
May 03, 2012 | Acer Timeline AS3810TZ Notebook
My mouse touchpad is locked. Keeps showing a diagram on screen with a red line thru the touchpad??
There may be a button towards the top of the keyboard (one of the ones with LEDs next to them) that turns the touch pad on and off. Otherwise, there is usually a keyboard combination (the Fn key in the lower left + one of the F1-12 keys) that can toggle it on and off as well. Otherwise, in the lower right hand corner, if you plug in a mouse, you should be able to right click the touchpad icon and re-enable it.
Aug 23, 2011 | HEWLETT-PACKARD ProBook 6460B
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
Help. I want to disable the touch pad on my Gateway M6866 laptop. Whenever I am typing and get near the pad, the typing goes all over the screen. Any help will be appreciated.
Follow these steps to turn on or turn off the touchpad and optional pointing device.
  1. From the Start menu, click Control Panel.Note: If your Control Panel is in Category View, click Printers and Other Hardware.
  2. In Control Panel, click or double-click the Mouse icon.
  3. In the Mouse Properties dialog box, click the Device Settings tab.
  4. Click to select the device you want to turn on or turn off, and then click Enable or Disable.
Mar 13, 2011 | Gateway M-6866 Notebook
Lenovo IdeaPad Y510 touchpad problem
Sounds like something with your motherboard. If an external mouse is doing the same thing it might be the mouse controller on the motherboard. If still under warranty give them a call.
Apr 15, 2010 | Lenovo IdeaPad Y510 Notebook
My cursor flies all over the screen and ends up in the top right corner of my screen all the time no matter what i'm doing. It seems to right click as it does it. Why is it doing this?
your touchpad is not working right. Use a USB mouse and disable the pad until you can get the pad replaced. Also, check the mouse drivers to make sure they are correct and up to date.
Nov 19, 2009 | Dell F3534 Touchpad
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
Disable Touchpad Clicking
Hiya, At the bottom right of the screen, by the clock, you should see an icon for the touchpad.....
Hint : Hover the mouse over the icons and wait for the "Pop-Up" Display to see what they do if your not sure.
When you find the one for the touchpad, simply right click it and scroll down to the option that says "Tap To Click" and left click it so that there is NO TICK next to it..........
........ This will DISABLE all tap click options and leave the touchpad as a touchpad and the buttons as buttons...........
Hope This Helps, Kind Regards,
Me :D
Mar 19, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
50 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
