Televison & Video Logo
A
Anonymous Posted on Feb 02, 2014
Mitsubishi CK-3513Rs About 4 years ago I had a popping sound of arching. It eventually stopped, but the picture became more green. I had it fixed for $350. and lasted for only 4 years and started again with the same results...green, but lived with it. Yesterday, I turned it on, but now I don't have any sound? I'm still not willing to give up, but have been looking for a schematic, maybe I can fix it, but that too has become futile. Hopefully you can point me to the two issues? Much appreciated
5 Related Answers
Anonymous
  • 337 Answers
  • Posted on Sep 12, 2006
SOURCE: convergence out of addjustment
You need to get a service tech for that problem,it might need new amps for the convergence and then adjustments that only can be done from the service menu.
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Apr 14, 2007
SOURCE: Mitsubishi CK-3513R - Horizintal white line
this ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Anonymous
  • 150 Answers
  • Posted on Jul 07, 2007
SOURCE: have sound but no picture
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Anonymous
  • 4402 Answers
  • Posted on Jan 24, 2008
SOURCE: Mitsubishi fix.....
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 08, 2008
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
Goodluck..
3answers
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
1helpful
No pic. or sound but power light is on
Most likely the blue picture tube arched and shorted out the horzontal output transistor.Very common problem with this chassis.Now if you have an electronics background you can most likley fix it, if not you will be dealing with finding a high voltage leak consisting of 31,000 volts which can kill you.That pop you heard was the high voltage leaking to ground.
Popping; sparking of Red Projector to metal frame
Sounds like the red CRT has an internal short. Sometimes happens that the picture tubes develop an internal short and cause arcing. I world CAREFULLY disconnect all of the wires to the CRT and see if the arcing goes away. VERY IMPORTANT!!! there is a high voltage wire attached to each pictur tube, usually a red wire that goes to the side of the tube. You can get a shock even if the TV is unplugged, as the tube will hold a charge for years after the power is disconnected. If you don't feel comfortable doing this, DON"T since the shock is powerful enough to stop your heart.
Mitsubishi VS50605, year 2000 green tinted picture
CHECK Q2A13 PART # 260P533010 ON THE RGB PCBOARD. ALSO CHECK Q6G02 PART # 260P696010 ON THE GREEN CRT.PC BOARD
IT COULD ALSO BE SOLDER RELATED ON THE GREEN CRT PC BOARD. LET ME KNOW IF YOU NEED ANYTHING FURTHER.
2helpful
5answers
Sony KP-57WV600 rear projection
sounds like bad CRT, some of these sonys have had defective CRT issues, usually all will come and go sooner or later (all 3 bad), you can pull the speaker grill off(either 2 1/4" screws on bottom or 6 1/4" on back sides) and pull off the Crt box cover (2'X3' piece) and lightly tap the CRT's with tv on, if they flare or get colored streaks in pix they are bad, CALL SONY 800 # and complain, also could adjust G2 (Screen control for color) for short patch. Will need new crts.
6helpful
5answers
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
