SOURCE: I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
SOURCE: Fitting a door seal to a Zanussi ZWD 1270SA washing/drier
Follow these steps to replace your door
seal:
For all Free appliance repair videos visit our VIDEO
TUTORIALS
Disconnect all power to the machine first!!
1 Locate the
outer clamp band securing the seal to the door rim on the washing machine and
examine it carefully for holes or tears. Many can be prised off with a
flat-bladed screwdriver they have a spring system holding them, but some have a
tensioning arrangement that has to be loosened.
2 After
removing the outer
clamp band, locate the inner one securing the seal to the drum and
establish how this is secured. It may be necessary to loosen a clip, or you may
be able to prise the band off with a flat-bladed screwdriver. Some are like
very large Jubilee clips that you have to undo usually from the top.
3 Once the
clamp bands have been removed, use both hands to pull the seal away from the
inner drum rim. Some machines have a water spout holes that will have to be lined
up. Others have a drain holes.
4 Rubbing a
drop of washing up liquid into the groove on the door
seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing
machine door seal should be fitted by locating the drain holes at the bottom
of the seal first then push it on with both hands working opposite directions
towards the top. This is quite hard if you have never done it before.
6 refit the
inner band remembering this must be tensioned correctly for it to be water
tight.
7 now fit the
outer band and the test the machine for any leaks,
All washing machine spares featured in this article are
available at apart4u with more video
help in our tutorial
section.
Information provided is a guide only. aPart4u accepts no liability for any
problems occurring whilst attempting any advice shown. If in any doubt about
fixing your appliance, always contact a qualified repairer.
SOURCE: My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
SOURCE: Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
SOURCE: I have a zanussi washer dryer ZWD 14270w and the
Not sure how full the drum is when you are using the dryer, but I have this appliance and it works best if the drum is half full. If the drum is full, things don't dry properly because the air can't circulate.
If that doesn't work I'm out of ideas!
