Blade stuck
SOURCE: Need to locate fuse
a thermal fuse may be located near the motor to sense an overheated motor. the fuse may be about 1/2 inch long and about 1/8 inch cylinder with two wire connections. these are available at Radio Shack or more. match the temperature rating...read the print on cylinder. if none found, look on circuit board for any print starting with letter "F". that part may be a fuse.
SOURCE: food processor
If the blade is actually fused, I would seek professional help to avoid slicing your fingers off. You can test to see if it is fused by removing the lid of work bowl, twisitng work bowl to the left, and removing the work bowl - if work bowl will not come off (difficult even under normal circumstances), then find out from Cuisinart if you are still under warranty.
SOURCE: grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
