E-Machines eMachines Desktop PC Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pc crashed and i had to switch the pc off by the switch
So when i switch back on the pc the moniter keeps saying its going to sleep and the comp has power going to it why does the moniter keep ging to sleep b4 the start up
  • Anonymous May 11, 2010
    Does it appear that the computer is actually starting up? I'm envisioning a computer where the power light comes on but you see no disk activity, hear no beeps or other sounds, and the keyboard doesn't respond to CapLock or NumLock.
    In that case it's a computer problem, not a monitor problem. Can you confirm?
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Jun 05, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
14123
Points
134
I agree it must be a PCI slot or video card problem .Try to change the videocard.
Came home to find computer off. It was left in sleep mode. The moniter keeps saying there is no signal and the keyboard has no power.
If its truely in sleep mode, and won't come out of sleep mode. Unplug the computer from its power, hold the power button down for 5-15 sec, then wait 2-5 full minutes. Then plug it back in, and turn it on.
If that doesn't work it is NOT stuck in sleep mode. Most dell computers I've worked with the caps go out in the power supply and/or the motherboard. I would next clean out the computer with canned air, check the caps on the motherboard, and in the power supply. If there are any bad caps, replace them, and it should fix it. Hopefully though the above paragraph fixes your problem.
Fixya solutions:: my question is about my Hewlett Packard model p6-2003W desktop blue light on ucp and moniter going to sleep and shutting off when I reboot or shut off power they both come on and I a
The problem can be correct in the control panel power options..
select hig performance as the preferred plan,
click change plan settings
change both sleep options to never>>
this is caused by a corrupted display settings in the registery and needs to be reformatted or restored using the factory restore disc to fix the problem. the above solution will work just remember to put your system to sleep manually and turn of your monitor.
Question about my HP desktop model p6-2003 computer blue light on and moniter going to sleep moniter going to sleep
in control panel, select the power Options,, Change the preffered plans to HIGH PERFORMANCE then click on change plan settings, change turn of diaplayto never and put computer to sleep never... Remember to turn on your screen saver and put the pc to sleep manually when not using it.
this is a common problem and caused by corrupted registry entries. The popper fix is to reformat or restore the system.
Power switch is staying in sleep mode. will not turn on or when it does turn on the moniter stays in sleep mode
use external monitor and go to control panel - power setings - here you can set up all you need
1helpful
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
My drive on my advent roma is not recognising any discs
You can try cleaning it with a cleaning disk but otherwise it does sound like the drive is going bad.
2helpful
My HP LCD screen keeps going to sleep.
ur comp has an estimated time set by the company which is 20 mins if ther is no activity on the comp it goes to sleep wht u ave to do is go in device manager and uncheck the box in display frm advance option in tht way ur comp will never go to sleep dont know if u will understand this not good at typing working for tech supp for hp used to talking no typing
Monitor is blank when comp is on
if the moniter light is keep lighting than there will be problem with your video card check the cable connections of your moniter . if ot not work than change your video card.thanks and take care
Mikomi ak-808u keyboard
When you press your power button your system goes to sleep mode as per your system settings. To awake your system just press any key or 'Awake Key' (if its present on your keyboard), then your system will be back. No need to wait.
Thanks
Iqbal
3answers
Moniter problems
the monitor have a problem
just replace the monitor
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
