be sure not to plug-in the pci adapter before installing the driver, here try this install first the driver of the said pci adapter then if ask to restart the computer restart it, then turn it off, now install the pci adapter then turn on the computer it will now detect the adapter then follow instruction on the screen, thanks
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc hope this helps or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIChttp://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
hope this helps
Please let me know from where i can download the following drivers for my Compaq Presario v2000 machine: 1. Multimedia Audio Controller 2. Network Controller 3. PCI Modem 4. Video Controller 5. Video Controller (VGA Compatible)
