Hello, I am having problems, my scooter says its fully charged so I go out, I don't get far when I loose all power and the battery indicator starts beeping. Please can you advise what this should be.
Hi, okay there two things the batteries and the charger, can you try another charger ?
1. Batteries need replacing ?? make sure battery terminal connections are tight.
2. How long are you charging the batteries for ? i hear you say that's a silly question however you be surprised how many people charge their batteries for a hour then remove the charger.
3. Is the charger faulty ?
4. there is a remote possibility of a controller fault however this is not common..
In relation to the charger if you're in the UK, I offer a free testing service , you only pay the return postage...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Feb 02, 2014
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
SOURCE: How can I obtain an operators manual for a
Just use Gooogle to get their website. Usually you can either download the manual or request one.
Posted on Jul 24, 2009
SOURCE: the battery is fully charged but the scooter will not move.
Is it the small portable scooter? The one with the base that comes apart for transporting? Could it be a bad connection where it goes back together?
If it is the portable, try disconnecting the rear drive portion from the base and re-installing it so it clicks into place.
Posted on Sep 22, 2009
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
SOURCE: need a manual for a freerider kensington S
most scooters are equiped with a seat that can be turned through ninety degrees so that it i eaier to get on and off the scooter if this is the cae for the scooter you have and own then turn the scooter seat ninety degrees so that the seat is side on to the base then grab a hold of the base of the seat and lift you sould find the scooter seat is easily removeable and can be then replaced in the same manner in some cases you have to hold down the lever that enables the seat to be turned to do this and lift the seat at the same time once you have turned it through the ninety degrees this is the case for almost all mobility scooters now however there are a few exceptions failing this then read te manual you should of got with your scooter when you purchased it however you may not have one if you purchased the scooter second hand but if this is the case you can usually find the appropriate soloution by entering the name and make and model of your particular scooter into a web search engine you may have to visit several web sites before you find the manual you are seeking but most of them are out there in cyberspace somewhere good luck and best wishes I hope your scooter brings you many hours of joy and freedom
Posted on Oct 01, 2010
May 06, 2017 | Cars & Trucks
Apr 24, 2014 | Health & Beauty
Sep 09, 2013 | Health & Beauty
Nov 28, 2012 | Electric Mobility Power Electric Scooter...
Jul 30, 2012 | Health & Beauty
May 12, 2011 | Invacare Supply Group Invacare Scooter...
Jul 01, 2010 | Electric Mobility Mobility Electric Power...
Sep 30, 2009 | Health & Beauty
