Question about Samsung HT-DB120 System
Aiwa vc87 does not power on - Samsung HT-DB120 System
Where can I find a power cord for a Aiwa CSD-TD901
http://audio.manualsonline.com/manuals/mfg/aiwa/aiwa_csd_csdtd901.html
The manual shows the electrical input and output required.
You might be able to locate a similar cable on eBay.com or in a second hand shop or charity shop for this model.
eBay has the entire device including the power cord for sale for $15.95 plus shipping:
http://www.ebay.com/itm/like/123051993560?item=123051993560&rmvSB=true
Apr 06, 2018 | Aiwa Audio Players & Recorders
Tip
Aiwa XR-DV370KN Region Free Fix
Aiwa XR-DV370KN DVD Player Region Free Fix
Would you like to unlock your Aiwa XR-DV370KN DVD Player to Region Free?
Follow these steps to unlock your Aiwa XR-DV370KN DVD Player:
  1. Press the Pause button on your remote control.
  2. Using your remote control enter the numbers 3, 1, 4, 1, 5 and 9.
  3. Press the 0 button on your remote control for Region Free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control.
  5. Power off your player and wait a few seconds.
  6. Power on your player.
Your Aiwa XR-DV370KN DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Aiwa troubleshooting
Press the POWER button while pressing the TUNER/BAND
button on the unit. See page 8 of the manual: https://docs.sony.com/release/CSDEL300.pdf
Aug 14, 2014 | Aiwa Audio Players & Recorders
Stand by problem
do have the the circuit book of aiwa nsx k880
Apr 08, 2014 | Aiwa Audio Players & Recorders
Aiwa mod. CX-ZR774 System will not power up
I assume that the Aiwa controls the other components, such as a CD changer. If these units are plugged into the rear of the Aiwa, then they may not be receiving power due to an auxiliary switch being off, or a bus breaker being blown. Breakers are on the back panel of the unit. They have a black thumbscrew that turns out counterclockwise. Take the fuse to Radio Shack to confirm if it is good or not, and good a new one if not. If the components are not connected to the Aiwa, then I have the ask the stupid question of are they plugged in, or is the surge protector that they are plugged into plugged in. Remember that even modern surge protectors have breaker switches, and may need resetting, especially after a snow or thunderstorm. Good luck.
Jan 27, 2014 | Aiwa Audio Players & Recorders
Hi, Can you tell me how I can get a replacement power cord for an AIWA Boombox with # CSD-TD26. Other power cord do not work , as AIWA's has a little tab inside that does not allow full engagment with the...
Aiwa has discontinued the original cord for this unit. However, Aiwa is Sony's entry level line. Most Sony cords used the style that was in the shape of an oval without any notches. If this is the case you can purchase the generic version through any national public distributor such as MCM.
Nov 30, 2010 | Aiwa Audio Players & Recorders
NEED TO REPLACE POWER CORD FOR AN AIWA CSD-ED87 BUT CAN'T FIND IT
Try a local Goodwill store or any second-hand store. Seems they are popping up everywhere these days.
These stores have plenty of electronics and power cords and transformers. If you have a simple power cord like most boom boxes (no transformer) they are easy to find at these stores.
Otherwise, go to www.alliedelec.com
you will pay about 15 with shipping.
Nov 18, 2009 | Aiwa CSD-ED87 Boombox
I've lost the power cord to my Aiwa CADW248
Radio Shack or similar small electronics shop. 5-10 bucks. Hope this helps
Jul 09, 2009 | Aiwa CA-DW248 Cassette/CD Boombox
Aiwa receiver AV-DV75 powers up then down instantly
mi se sfiza aiwa sistmi buferi ali nemam moznis da kumim.....
Jan 02, 2009 | Aiwa AV-DV75
Samsung HT-DB120 System Logo
18 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
