Question about Xerox DocuColor 12 Printer
Copier printer doesn't start. It says failure system, please turn off and then turn on again. 9-356 Please, if you have any solution for me, I'll apreciate it.
Posted by rohanme31 on
Anonymous
    Problem Solver:
  • 7 Answers
Maybe Cyan developer is too full. U should make max setup.
U can resset this error in nwm
776-062 to 0
776-374 to 0
Posted on Jul 30, 2009
docukaaf
    Habit-Forming:
  • 38 Answers
The low toner sensor detects that is not cyan toner for a period of 8 minutes. Probably the augers are blocked disasembly and clean the augers or change the toner dispenser motor
Posted on Jun 06, 2009
1 Related Answer
Rick Kasper
  • 2072 Answers
SOURCE: code error # 9-356
That is a yellow toner empty message.
Posted on Apr 13, 2008
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Failure Oxc05d0082
Hi eherndl,
The failure Oxc05d0082 description is a pump stalled error, it is often caused by the ink system has failed. To correct this error please follow the steps below.
1. Power drain. Please unplug the power cord at the back of the printer. Press and hold down the power key for 30 seconds then release the key and plug the power cord back in.
--> if this doesn't work please proceed to the next step.
2. Partial Reset. Please unplug the power cord at the back of the printer.Press and hold the # and 3 keys together and while holding them plug the power cord back in. Check if the problem is resolved.
If Not
3. Semifull reset: Unplug the power cord from the back of the printer again. Press and hold the # and 6 keys together and while holding them plug the power cord back in.
4. If you're still encountering the same error, please remove all the print cartridges (with the system powered up). Clean the copper contacts with the help of a lint free cloth then reinstalled them. Allow the printer to go through its normal sequence then go to the Setup, select tools, then clean print head.
Hope it helps.
Thank you for using FixYa.
May 01, 2011 | HP Photosmart C6180 All-In-One InkJet...
When turning on copier it starts on the start up screen (has a picture of copier). It never changes and says printer is offline for printer as well...
On Toshiba's this is almost ALWAYS a hard drive failure. Toshiba loads the "firmware" or operating system on the hard drive so when it goes bad the copier will turn on or say please wait but that is all. You will need a Toshiba tech to come out and replace the drive as well as load the firmware onto the new drive. You can not simply replace the drive on these machines like you can most other copiers.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 31, 2011 | Toshiba E-STUDIO 720 Copier
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
Ink system failure
Hi
Thanks for using FixYa. To resolvethe issue of display of error Oxc19a0036 you’ll need to reset the printer andto reset it please follow the step-by-step procedure on the link---
Howto Reset Photo Smart Printers
Please do rate the solution andrevert for further assistance.
Thanks
Rylee
Jan 21, 2010 | HP Photosmart D7560 InkJet Printer
Ink system failure on photosmart c5380 0xc19a0036
Hi
Thanks
Rylee
Jan 17, 2010 | HP Photosmart C5380 All-In-One Laser...
Our copier doesn't copy and shows error message "unable to print..." we want to get it fixed, please help
The graphics is not initialized
because the graphics memory
was not reserved. This error
rarely occurs unless the printer
detects the memory failure.
Please note that
“RPCS”(RICOH printer language)
is the same worldwide
and does not need to be translated
Replace the installed memory.
Turn the power off, and then on. If the
message appears again, contact your
sales or service representative.
Oct 02, 2009 | Office Equipment & Supplies
Remove original document from document processor
okay i imagine you have software
control panel add/remove
uninstall any old printers/scanners/copiers
also uninstall the printer you just added
restart your system make sure new printer plugs are in correct
then reinstall your software before trying to use restart system
please let me know what happens
what version of windows do you have
Feb 11, 2009 | HP Computers & Internet
Code error # 9-356
Apr 12, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
217 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
