Question about HP Laserjet 2200dn 2200 Dn Printer Duplex Network
Dpi economode - HP Laserjet 2200dn 2200 Dn Printer Duplex Network
Posted by Habibur Rahman on
Arpit
    New Friend:
  • 29 Answers
You can change setting of economode in EWX page
Posted on May 05, 2014
HP LaserJet 1007 Prints Light
First of all check your printing preferences
  1. Right-click the product icon, and click Printing Preferences to open the Printing Preferences window.
  2. Click the Paper/Quality tab.
  3. Check the paper or media type setting.
    1. Find the Type is: drop-down list.Figure 1: 'Type is:' drop-down list in the Printing Preferences windowc01855301.gif'Type is:' drop-down list in the Printing Preferences window, Paper/Quality tab (screenshot)
    2. Select the paper or media type you are using.
      • For thinner paper, select Light , Thin , or Vellum .
      • For thicker paper, select Heavy or Thick .
      NOTE:HP does not recommend the use of heavily textured paper, extremely thin paper, or paper with a basis weight heavier than 90 g/m2 (24 lb).
  4. Make sure the paper or media type setting is appropriate for the fuser temperature.NOTE:Unlike ink printers, laser printers use heat to fuse a plastic toner to the surface of the paper. Make sure to use heat-resistant paper, and labels and envelopes that use adhesives compatible with the heat and pressure of the product's fusing process.
    1. If you are experiencing any issues in the following list, adjust the setting.
      • If the paper is curled or wavy , try the following:
        1. Decrease the fuser temperature setting. To do this, select Light ,Thin , or Transparency .
        2. Use the archive print feature to improve toner fusing. To do this, select Archive or Bond .
      • If the printout has areas of fuzzy or dark print , or toner scatter , increase the fuser temperature setting.
        1. Select Heavy or Thick .If this does not resolve the fuzzy, dark print, or toner scatter issues, use a lower basis weight or thinner paper.
  5. Click Apply .
Step three: Check the print density settingsFollow these steps to check the print density settings in Printing Preferences and in Properties.
  1. In the Printing Preferences window, click the Paper/Quality tab, and find the Print Quality section.Figure 2: 'Print Quality' section in the Printing Preferences windowc01855302.gif'Print Quality' section in the Printing Preferences window, Paper/Quality tab (screenshot)
  2. If you are experiencing any issues in the following list, adjust the settings.
    • If the entire page is too dark , change the dpi setting, and turn on EconoMode .
      1. Select 600 dpi from the drop-down list.
      2. Select the EconoMode check box.
    • If the entire page is too light , change the dpi setting, and turn off EconoMode .
      1. Select FastRes 1200 from the drop-down list.
      2. Clear the EconoMode check box.
  3. Click Apply , click OK , and then close the Printing Preferences window.
  4. Open Printer Properties. To do this, right-click the product icon, and click Properties .
  5. Click the Device Settings tab, and find the Print Density section.Figure 3: 'Print Density' section in the Properties windowc01855303.gif'Print Density' section in the Properties window, Device Settings tab (screenshot)
  6. If you are experiencing any issues in the following list, adjust the setting.
    • If the printout has areas of gray shading or a gray background , decrease the print density setting.To do this, slide the bar to the left .
    • If the printout has light, dull or faded areas , increase the print density setting.To do this, slide the bar to the right .
  7. Click Apply , click OK , and then close the Properties window.
  8. Try again to print.If these steps do not resolve the light, dull or faded issue, the print cartridge is almost empty. Skip to Solution eight: Replace the print cartridge .
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.If this don't help you, here is instructions for refilling a toner cartridge.
http://www.uninetimaging.com/downloads/technical/hp/english/HP_P_1006_Reman_eng.pdf
Maybe you need to clean the drum, blades or the developer roller. Maybe the problem is in the toner you use.
Jul 08, 2012 | Office Equipment & Supplies
300 dpi against economode
DPI mean Dot per inch. Ecomode will economize your ink but 1320 dpi will print high quality with more ink usage
Nov 25, 2011 | HP Office Equipment & Supplies
Hp laserjet p3015 prints really dark. how can i lighten it?
EconoMode This product has an EconoMode option for printing drafts of documents. Using EconoMode can use less toner and decrease the cost per page. However, using EconoMode can also reduce print quality. HP does not recommend full-time use of EconoMode. If EconoMode is used full-time, the toner supply might outlast the mechanical parts in the print cartridge. If print quality begins to degrade under these circumstances, you will need to install a new print cartridge, even if there is toner supply remaining in the cartridge. Enable or disable EconoMode in any of these ways:
  • At the product control panel, select the CONFIGURE DEVICE menu, and then select the PRINT QUALITY submenu. EconoMode is turned off by default.
  • In the embedded Web server, open the Settings tab and select the Configure Device option. Navigate to the Print Quality submenu.
  • In the HP Printer Utility for Macintosh, click Configuration Settings , and then click Economode & Toner Density .
  • In the Windows PCL printer driver, open the Paper/Quality tab, and select the EconoMode option.
Mar 08, 2011 | HP Laserjet P3015X Printer
I have HP LaserJet 1160 Printer, moreover it prints dim (light) print on paper. I replace its toner, yet it is printing dim printing..... can you give me reason, what is problem?
Hi, maybe the printer is in EconoMode. To disable EconoMode please open the printig preferences in Windows. On the Paper/Quality tab or the Finishing tab, deselect the EconoMode checkbox.
Jul 19, 2010 | HP LaserJet 1160 Printer
How to get 300dpi from hp1020 laser?
HP support does not list the dpi for its "EconoMode (Save Toner)" setting, however the next highest setting is 600 dpi.
If you are printing drafts and want to save toner, the EconoMode can be chosen in Control Panel from one of your printer's properties tabs.
Mar 13, 2010 | HP LaserJet 1020 Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
300 dpi priting
Your printer doesn't have a 300 DPI setting, however, you can select "EconoMode" from the "Preferences" menu after you select "Print". Look for a tab that says "Quality". EconoMode will be lighter than normal 600 DPI printing, thereby saving toner.
Nov 13, 2008 | HP LaserJet 1010 Printer
Print has started coming out very faint. difficult to read. can i set machine to print darker or revise resolution
Sounds as if your toner cartridge may be nearing the end of its life or you've got the economode turned on. If it's the latter it can be turned off in the printer driver - printer Properties -
On the Paper/Quality tab or the Finishing tab -
uncheck the economode box.
May 16, 2008 | Brother Office Equipment & Supplies
HP Laserjet 2200dn 2200 Dn Printer Duplex Network Logo
48 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
