Question about Intuit QuickBooks Pro 2007 Full Version (299116)
I have been getting error code -6000; -83. What
I have been getting error code -6000; -83. What do I do to fix?
Posted by kathypeterpa on
  • 2 more comments
  • Akshay M
    Akshay M Jun 30, 2020
    This Error code can be resolved according to the action causing the error; when you try to open the company file, when you try to restore the company file and when you try to create a backup.
    Trying to open the company file.
    a) The manual fix of Quickbooks error 6000 83 error QuickBooks.
    Configure the security software settings in favor of QB.
    Verification of permissions to use the company file are obtained.
    Scanning of the folder in which the company file is stored to create the Network Descriptor file.
    Put an end to multi-user access for hosting the company file.
    Opening the company file from a different location to the original one by copying the file to another location to open it. If successful, the company file can be copied to the original location.
    b) Use of QuickBooks file doctor.
    The program provides QuickBooks File Doctor software that helps to fix QB error 6000 83. The time taken rectifying the file depends on the size of the company file.
    c) Turning off all devices trying to gain access to the company file over the network.
    Hosting on all computers should be turned off
    If the message “Hosting multiple user access” still appears, means your pc is not hosting your QuickBooks file.
    Click yes on the “stop hosting multiple user access” message.
    Click yes on “company file must be closed” and proceed.
    Follow the steps in another computer.
    Attempting to create a backup company file.
    Follow the steps below.
    Create a new folder in drive c.
    Create a manual backup and save the new file folder in drive c.
    Attempting to restore the company file.
    QuickBooks considers the entire file path and name, therefore, ensure there are no special characters in the name and path of the file.
    The company file should always be .qbw during backup restoration.
    Learn more about
    QuickBooks Hosting Services
    QuickBooks Enterprise Pricing
    QuickBooks for Mac Desktop
  • Mark Wilson
    Mark Wilson Mar 29, 2021
    Causes of QuickBooks Error 6000 83
    Listed below are several causes that can lead to QB Error Code 6000 83:
    Damaged company file or folder.
    Firewall or browser has blocked QuickBooks files.
    The file extension is incorrect.
    Incomplete QuickBooks installation.
    Multiple workstations trying to host the company file.
    The server has limited access to the company file.
    The current user doesn’t have permission to access the file.
    Any security software is blocking access to QBDataServiceUser.
    Solutions to Fix QuickBooks Error 6000 83
    Different operations on company file cause and different operations call for different solutions. The operations are when the user is trying to open the company file; when the user is trying to restore the company file and when the user is trying to create a backup.
    User Attempts to Open the Company File
    Fix the QuickBooks 6000 83 Manually
    To begin with, Configure the Firewall or security software settings in favor of QuickBooks.
    Then, you have to verify that the permissions to access the company file are available.
    Scan the folder where your company file has been stored so that you can create the Network Descriptor file.
    Stop the Multi-user access for hosting the company file.
    Try opening your company file from a location other than the original one. You can do this by copying the file to another location and opening it. If this is successful, you can simply copy it back to its original location.
    Use QuickBooks File Doctor
    QuickBooks File Doctor Software can help you fix QuickBooks Error Code 6000 83. Depending on the size of your company file, the process may take a little while.
    I hope both these methods will be helpful to fix QuickBooks Error Code 6000 83.
    Mark Wilson
  • Anonymous Mar 29, 2021
    2009 post, he/they are long long gone now and have QB online now, like smart folks do.
    necro max record winner./
Hp Printer Support Assistant
    Novelist:
    Habit-Forming:
  • 76 Answers
Why QuickBooks Error 6150 occurs?
  • "QBW" or company file is damaged. You need to create a "Portable backup file."
  • A damaged or corrupt QuickBooks installation
  • You are trying to open a portable file (.qbm) without opening QuickBooks.
  • A changed or wrongly typed extension for QuickBooks file.
  • Trying to save "QuickBooks Macintosh file" while using QuickBooks for Windows.
  • The company file is infected with the virus.
Methods to Fix QuickBooks Error 6150:
  • In case the "QuickBooks Error code 6150 and 1006" message is linked to a "file-extension" of the company file, then you need to consider changing the "File extension" and saving the company file with a correct extension.
  • Ensure and verify that the "QuickBooks company file" is opening on another computer.
  • Try to re-install QuickBooks, if the file is not up-to-date,
  • You need to save "QB for Macintosh in the Mac system & not in Windows-based system & vice versa)
  • Update with a good anti-virus before opening up the "company file."
The above steps may be sufficient to resolve the QuickBooks Error code 6150; however, they may not be sufficient in many cases. Try the techniques below to address the problem.
Method 1- You require to restore from Backup:
If the above method has been pointless in resolving QuickBooks Error Codes 6150, the next best move is to restore from backup the "Company file." Let us look at the same steps:
  • Navigate to QuickBooks
  • Click File
  • Select" Open or Restore Company
  • Choose to "Restore a backup copy" & click ""
  • Select "local backup" & click ""
  • Choose the location of " company file backup" from the "Look-In" drop-down list
  • Click "the backup," and it should be available with a ".qbb" extension
  • Press "Open" and then click ""
  • Now go to "Save in" drop-down window & browse to the desired location to restore the backup file.
  • In the "File-name" field- type/enter a "new company "
  • Check that the "save as filed" should have been automatically saved to restore the file in the ".qbw" format.
  • Select "Yes"
  • Now type "Yes" to confirm the overwrite process.
Posted on Sep 06, 2019
micheladamss
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
To restore QuickBooks file you can use the updated backup of your QuickBooks data, this will allows you to restore your entire file data without need of any extra effort. In case you don't have any backup file or unable to do restoration process through backup file then you can use QuickBooks Recovery Tool that can repair all the corruption of Quickbook. It is very easy to use and fix all the damaged or corrupted Quickbook file.Some of QuickBooks Error Messages Fixed & Repaired by QuickBooks Recovery Tool like:-
- QuickBooks Error 6000-80
- QuickBooks Error 6000-83
- QuickBooks Error 1334
- QuickBooks Error 6129
- QuickBooks Error code 80070057
Free Trial version of Quickbooks Recovery software allow you to display the preview of recovered data in evaluation version.
Posted on Jun 08, 2017
jon markan
    Habit-Forming:
  • Intuit Expert
  • 256 Answers
1. You are opening your company file
  • You are storing your company file on a Windows server
  1. Solution 1: Fix the error using the QuickBooks File Doctor
  2. Solution 2: If you're using QuickBooks on more than one computer, configure only one to host the company file:
  3. Solution 3 (Optional): Manually resolve -6000, -83
  4. Solution 4: Edit the hosts file
  • You are storing your company file on a Linux server
2. You are restoring your company file
  1. Solution 1: Change the extension if the restored file extension is .qbm or .qbw.adr instead of .qbw
  2. Solution 2: Check for problems in your file name and file path
3. You are creating a back up
for more help visit
QuickBooks Tech Support
Posted on Aug 08, 2014
Jon Edlund
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Might I suggest going to the Getsatisfaction website. I have provided a link that will direct you there.
http://bit.ly/7ebRo
You can use OpenID, Windows Live/Bing, or create a new username.
Hope they can help you out.
Posted on Jun 05, 2009
7answers
How to Fix Microsoft Office Error code 30016-4?
Have you tried checking Microsoft ? or Google / Youtube for a fix . . .
2answers
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
I got code 108 eror
How to solve 108.xx, 108.08 error on Lexmark printers ~ Fix ...
fix-your-printer.blogspot.com/.../how-to-solve-108xx-10808-error-on.ht...
How to solve 108.xx, 108.08 error on Lexmark printers. A 106.xx, 107.xx, 108.xx, or 109.xx error indicates a problem with one of the ... Libell?s : Error code ...
IBM OPOS, Common Error/Return Codes - United States
www.ibm.com/support/docview.wss?uid=pos1R1000395
IBMMar 30, 2006 - I'm new to OPOS and get error return codes or result codes. What do ...108, OPOS_E_OFFLINE, The physical device is not connected or not ...
why am i getting error code 108 - QuickBooks Learn & Support
0176 code error what can i do to fix the problem
What were you doing to get this error code? When does the error appear?
3answers
Windows update error 80240016
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
Top Intuit Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
