Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Freezer moans Our freezer moans loudly for hours at a time. It appears to be coming from the  motor/fan at the  top of the freezer.Then it will stop suddenly and inexplicably. Because the problem is intermittant, I'm hesitant to call GE repair, because you can bet the freezer will be quiet while they are here. It's really really irritating. Sarah
Posted by emmabean on
Anonymous
    Sergeant:
  • 274 Answers
Got a tape recorder or video camera?  Tape it and then call the service guy.  Then if it's "not" acting up when he gets there you can show him!  I did that once...it works.
Posted on Oct 25, 2007
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our refrigerator just suddenly started to make this loud grinding sound..it appears to be coming from the freezer side. I turned off the ice make and reduced the freezer temperature but it still keeps...
This could be a failure of the evaporator fan. Also maybe some ice has formed from water dripping from the ice maker and had now produced an icicle which could be hitting the fan blade of the evaporator motor. Remove back cover to the freezer/fan and check the fan operation while it is running.
Mar 29, 2010 | KitchenAid Refrigerators
I have a Frigidaire Upright Freezer making strange noise.
Check the condenser fan,m sounds like the bearings are failing.
Good Luck,
Gilsh
Nov 28, 2009 | Refrigerators
Ice is forming in my Freezer and the roof is forming drops
Unplug it and let it defrost. wile it is defrosting pull the botum front cover off and vacum out all of the acumulated lint off the tub on the bottum. after about 2 -3 hours plug it back in and listen for the fan running on the inside if you feel air coming out of the vents then you should be OK. If no fan replace it.
Sep 11, 2009 | Kelvinator 24 in. MDB421RF Built-in...
GE Model GSS22JERFBB moaning sound form freezer section
That's the fan motor. Either the fan blade is hitting something or the motor is going bad. Either is a cheap fix.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Noise intermitently from top ( freezer section)
in the back there should be a small cover with vent holes in it,that holds on with 2-4 screws,take that off and you will see the fan.REPLACE the fan motor,it may or maynot come with a fan blade,the motor alone is about $60.00,get the model number from inside the fridgerator
Apr 18, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Refrigerators Logo
233 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
geob91
