Question about Alpine CDA-9857 CD Player
Alpine CDA-9858 CD Player - Alpine CDA-9857 CD Player
5 Related Answers
Anonymous
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
Anonymous
  • 11 Answers
SOURCE: ALPINE-CDA-9854R Radio works but the panel won't light up
the counters on radios with detachable faces go bad forum coronation sum times try a small nail file on them to clean it off
Posted on Dec 15, 2007
Anonymous
SOURCE: Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Posted on Nov 06, 2008
Anonymous
SOURCE: alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Posted on Aug 31, 2009
Anonymous
  • 12 Answers
SOURCE: I have an alpine cda-9883 cd won't eject & error
try detaching the "face" and there should be a little button that you can only push in with some kid of really thin stick,maybe a pin that will reset the cd player and hopefully work
Posted on Dec 15, 2009
Time set
Hello
Try to download its user manual from any one among the folloing links. It will have all details.
http://www.pdfjungle.com/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player-pdf-preview/
http://www.dataentryjobs.us/67948.html
http://www.retrevo.com/support/Alpine-CDA-7998-Car-Receivers-manual/id/23223dj397/t/2/
If you feel any difficulty in downloading the manual, inform me by Fixya comment, along with your email address. I'll send a copy of the manual to your device by return mail.
Mar 10, 2012 | Alpine CDA-7998 CD Player
Is the CDA-9827 capable of playing songs from an mp3 player (does it have an input option)?
The Alpine CDA-9827 only has an input connector for an external CD Changer.
You could get an FM Transmitter for your MP3 Player, and play your MP3 Player using your FM Radio in your Stereo.
Here is an excellent MP3 Player FM Transmitter:
http://astore.amazon.com/tps03-20/detail/B000E43GOO
Here is a copy of your Owners Manual.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 24, 2010 | Alpine CDA-9827 CD Player
Oct 27, 2009 | Alpine CDA-9883 CD Player
Alpine cda- 9883 radio will not recognize ipod
your ipod might be too new,and your cd player too old the alpine cda 9883 is a 2007 model what kind of ipod do you have,if uyou have an older ipod and got the new itunes9 then try downloading an older version of itunes from itunes.com .....good luck
Sep 26, 2009 | Alpine CDA-9883 CD Player
I NEED A INSTRUCTION MANUAL AND WIRING DIAGRAM FOR A ALPINE CD 78
http://vault.alpine-usa.com/products/documents/OM_CDA-7893.PDF
Feb 18, 2009 | Alpine CDA 7893 CD Player
Alpine cda 9853 cd player
go to fader and turn it down
Dec 22, 2008 | Alpine CDA-9853 CD Player
CD Player
YOU PROBABLY HAVE A FAULTY UNIT
Mar 07, 2008 | Alpine CDA 7893 CD Player
Open Questions:
Alpine CDA-9857 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
