Question about Acer Aspire 5050-3242 Notebook
Acer arcade comprehensive multimedia suite
2 Related Answers
Anonymous
  • 57 Answers
SOURCE: Where can i download acer arcade or acer arcade deluxe for my notebook
what is it?a support driver?you can download it in acer website by using correct searce engine and by inputing the correct model.
Posted on May 19, 2008
Nitin_Master
Nitin Bhatt
  • 846 Answers
SOURCE: hi, I had to reformat
Part 1 (Download link)
Part 2 (Download link)
Password : komku.blogspot.com
NOTE:- It's only for windows XP
**Please rate and give a positive testimonial...If you find my solution helpful**
Have a Nice Day
Posted on Oct 17, 2010
Dear Sirs, I require an original manual / technical documentation or copy for the SEGA Astro City arcade cabinet.
You can find a PDF file of the manual at arcadecontrols.com, I don't know much about arcade cabinets, but the documentation seemed pretty comprehensive. Good luck!
http://files.arcadecontrols.com/details.php?image_id=3564
May 09, 2011 | Sega Video Game Consoles & Games
Can not play cd's or dvd's
There is no need to use acer arcade, you can just use windows media player or windows media center (which is acer arcade just changed a little by acer). The only way to recover acer arcade would only be possible by using your acer program recovery disks.
Feb 09, 2010 | Acer Aspire 6920 Notebook PC
I need the program acer arcade for my pc,
Here is a link to another page that has download links for acer arcade depending on the windows version you have running.
http://komku.blogspot.com/2008/05/download-acer-arcade-deluxe-for-windows.html
Oct 28, 2009 | Acer Aspire 5315 Notebook
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
How do i operate my acer crystal eye on acer 4710 notebook
I can't verify this, but it's worth a shot:
Go into Acer Arcade or Acer Arcade Deluxe OR go into Windows MediaCenter and then select Acer Arcade. Once in Acer Arcade there should bea program called DV Wizard. Once in DV Wizard select Acer Crystal EyeWebcam and the rest is obvious. Once you are done and click stoprecording, the video that you recorded will be in your Videos folder.
Source
Jan 03, 2009 | Acer Aspire 3610 Notebook
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
Wifi connectivity problem
there are three levels of switches for this model
one is mechanical on side or front..check..
one is the network connections enable switch..control panel accessible...check..
third on is the repair this connection, bottom right on tray..right click to repair...check..
try that on for size
Oct 04, 2008 | Computers & Internet
May 19, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5050-3242 Notebook Logo
101 people viewed this question
Ekse
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
