Zebra P120i Thermal Card Printer Logo
Posted on Jun 05, 2009
I have a zebra p120i card printer now when printing id cards for my company theres always a vertical yellow line on them. Can someone help please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
283
Points
Zebra p120i reads out of memory
My zebra p120i wont print, it just says error in print command.
Printer and Drivers(W XP), Printers(W Vista or higher version) Go to the driver by right clicking and printer preferences, then go to the tools settings, you will see the possibility to print a Test Card...Print it. If nothing happens and you are sure you have the supplies, Connection and power, it means you should check on the cable.
2answers
Label are printing so light you can hardly see them.
this problem setting printer propertises
you check it then color cartige select.
My Zebra P110i is not printing it's cards correctly, When I print a card, there is always a 2mm blank line gap on the end of the card where the printer has not printed on it. I've cleaned the printer,...
The Zebra P110i printer is an Edge-To-Edge card printer, which means it will print on the card closest to the edge as possible, however there will still be a slight line. Although a 2mm line is too big, should be no more than 1mm, there will still always be a line.
There are some advanced EC (end card) settings that could be adjusted but if the print goes too close to the edge, the ribbon will get cut.
-- The Pros at www.DiscountIDStore.com
1helpful
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
3answers
I'm printing a double sided card. The back side comes out fine (white with black letters). The front side needs to be completey black with red letters. It keeps coming out blurry. How do I fix that?
It may be that the ribbon is mispositioned. There are quite a few points in the trouble shooting section of the owners manual. These start on page 53. Here is the link to the page at the zebra company site that you can download the manual from.
http://www.zebra.com/id/zebra/na/en/index/products/printers/card/p120i.4.tabs.html
Hope this helps,
Best Regards,
Mark
Zebra p120i reads 'Out of Memory'
?? try to flash the firmware,http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/firmware/results.html?productType=6
Zebra P110 ID card printer card jam on yellow ribbon.
In the driver go to the tools section. In the command to send to the printer box type !SA then choose send the will calibrate all your sensors. As always make sure your clean the printer.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
