Question about Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt
Wiring diagram hf50 patton
Wire came loose
2004 pontiac montana..had loose grd screw on batt..loosed support bar for fuse box and moved aside while tightening .now no inst working. radio is locked out..runs well..
Either pulled wire loose or blew fuse. At least you know area to look for loose wire. Find wiring diagram and the find color of wire for instruments that will narrow your search.
Oct 14, 2017 | Pontiac Cars & Trucks
I put a 80-81 Cdi on a 82 xlh, runs but backfires should I advance or retard
probably retard it a bit but I don't think it is the timing
You say it runs and backfires but if the timing was too far advanced it would backfire on starting and be difficult to start
I suspect the fault to be electronic ---like a loose wire on the coil , faulty coil, faulty ignition control module, loose wire at ignition switch, loose ground wire , loose ground wire on battery
look for something that is making and breaking contact at random as that action induces a spark at the wrong time
Feb 27, 2016 | Motorcycles
While running a cleaning program it turned off and won't power up
You may have a loose power wire down in the electrical box on the dishwasher. Sometimes the wire nuts come loose if they are not securely fully. A loose wire may give it enough power to light the control panel and when the water valve turns ON the amperage increases, then the wires will push apart. This is because the two loose wires become magnetically similar poles and push apart. I have fixed many dishwashers by turning OFF the power to the dishwasher. Removing the lower kick panel opening up the electrical box, then removing the wire nuts, then reattach the wires together with the wire nuts again. Turn ON the power and see if the washer now works. If it does, then reassemble the dishwasher.
If this does not work, then you may have a loose wire connection in the control panel.
Sep 09, 2015 | Dishwashers
My compresssor keeps tripping the breaker>
Loose wire in panel box or loose wire around compressor. any loose wire causes a high amp draw which blows the breaker. I've found wires that look good but are loose. Go right to the compressor outside and check there first. pull disconnect first and make sure there is no power. you either have a shorted compressor or loose wire. if you ohm out compressor with power off and disconnect the three wires you will get something like this....one wire to other wire 2 ohms... same wire to other wire 3 ohms... other two wires you should get 5 ohms...2+3=5 good compressor.they will add up to each other.
Sep 28, 2014 | Heating & Cooling
Lights not turning on
Check wiring, check wire nuts, check bulbs. it will be something simple.
Loose neutral wire.
Loose bulb, 3-way switch wired wrong.
Loose wire on breaker.
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 25, 2012 | Electrical Supplies
Honda crv 2000, no instrument panel light, no park , front fog or tail lights. checked fuse(ok) but replaced anyway
check for loose negative wire on battery terminal, tighten if loose,
check your ignition switch, the accesories wire (positive) if loose/ re-connect it.
check for loose accesories harness wire- repair if nescessary.
Sep 17, 2011 | Honda CR-V Cars & Trucks
Yoy can jump the truck off, but wile you are
It is probably a loose ground wire. If it only does it while hitting bump, then there is a loose wire somewhere. It may be loose fuse but probably loose wire or solder joint going to dash control board
Jul 02, 2009 | Chevrolet Crew Cab Cars & Trucks
Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt Logo
204 people viewed this question
Top Patton Electric Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Patton Electric Heating and Cooling Expert? Answer questions, earn points and help others
