Question about Cameras
My Digilife DDV-A700HD will not power up. I have
My camera will not power up. I have tried charging it via USB to computer, the power cord and car jack. When I plug it in to power it, the red light comes on, showing that it has power, but it never charges.
Posted by shopper_bett on
Anonymous
I had the same problem with my camera so I had to replace the battery. I could not find the replacement battery that was in the camera. So I did a search and found out that the fuji np- 60 3.7v 1050w worked in the camera. I order the battery and now my camera works just find. I hope this help.
Posted on Nov 11, 2009
2answers
I have DigiLife DDV C511 Problem : Camera can not operate with batery, but can operated with power supply (batery charger). Name : Imam Organ Address : Sangatta - East Kalimantan - INDONESIA E-mail : imam...
Halo P`Imam...
dari keluhan Bapak, kemungkinan baterai yang digunakan tidak memiliki daya yang cukup untuk mengoperasikan kamera
Coba ganti dengan baterai yang memiliki kapasitas lebih besar
Kemungkinan lain adalah terjadinya malfungsi pada penghubung daya baterai, dna sebaiknya ditangani oleh teknisi khusus
Terima kasih semoga membantu!
3helpful
I had my digilife ddv-1100 for approximately three years and It no longer charges. If I pulg the usb in the light comes on but as soon as I disconnect it it goes right back off. What could be the problem?...
Almost certainly the battery. They don't last forever.
MY DigiLife DDV 7000 uses an NP-60 battery. I found some of these on Amazon by searching for "np-60", and paid about $1.50 each. You can also sometimes find batteries by searching on the Camera's model number.
My camera does not charge the battery from the USB lead. I have to use a separate charger.
How to use digilife DDV 7000 cmcorder as a webcam? can't use the flash of digilife DDV 7000 cmcorder
You have to install a driver to use this camera as a webcam. There is a Windows one posted at:
this site
It is actually for a different model, but works. Once you have installed it, your camera will show up as a source when you use a program that captures webcam pics or video. You will need to connect the camera to your computer with a suitable USB lead.
To turn the flash on and off in still picture mode, you press the right pointing arrow on the round selector switch array. There are two settings, off and auto, so you cannot force it to flash- it will only do it when the camera decides the light is low. The flash does not work when filming video.
Problem ddv-v1
la verdad no se entiende tu problema se mas especifico charly
Will not power on
It should power on using internal memory. Your problem is normally due to weak/dead batteries. Make sure that you have fresh batteries, or freshly charged batteries, installed. If changing the batteries out does not eliminate the problem, the camera is a likely candidate for the repair shop.
Bill B.
San Antonio
2helpful
Is not DDV-C330, is Digilife DDV-6120A
Find the DDV-C330 manual for download here:
http://chinamanuals.com
It is the same cam like the 6120A
Digilife DDV-7300 Camcorder - Battery will not hold charge
Not sure of which model exactly your using, but you may check out the web address below.
It appears to be a Chines manfactured Brand, unfortunately alot of these units appear to suffer from a substandard charging system that leads towards a problem with the battery.
The good news is that many mobile phone batteries are often suitable replacements for these to swap out with. I'm picking its probably around a 4.8v or similar flat type battery and is charged either via computer USB connection or through independant charger. A local camera shop won't be a good bet, the shipping to china may out weigh the cost of replacement. I would suggest hunting for a custom battery manufacturer that can supply a replacement battery and hopefully a charger to suit! :o)
As for the on off switch, also a common flaw in the designs, any local video camera repair shop should be able to assist with that part of it. Hope this helps.
http://www.lightinthebox.com/producttags/Digilife-Camcorder-Ddv-C330/
5helpful
My Digilife DDV-1100
the camera's battery won't charge with the usb cable connected to the computer, only with the 110/240 v charger. Hope I can help
I lost My digilife ddv-c330 cd
cn sme one send me digilife ddv -c33 cd copy plzzzzzzzzz itzz really urgent
Open Questions:
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
