Question about Linksys WRT54G2 Wireless Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on the router itself are lit up. I don't know what's up.
Posted by taimdis on
  • Anonymous May 11, 2010
    Are you connecting wirelessly?
Anonymous
  • 108 Answers
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Posted on Jun 07, 2009
1 Related Answer
Anonymous
  • 31 Answers
SOURCE: 321 error
try this power of both pc and router , unplug router power on pc then power on router see if it then picks up the isp, if not just simply unpup router and plug it back in while pc is running hope this helps!!!! good luck
Posted on Mar 23, 2009
1helpful
Error 321 linksys WRT120N
Are you trying to run the CD that comes with the router ?
You get this error when your computer is not able to connect to the router.
Actually you can say that it is a bug in the CD.
Even if your computer is connected to the router, it will say that it is not connected.
You can set up the router manually without the CD.
make sure that your computer is connected to one of the Ethernet port on the router.
Reset the router for 30 seconds. wait for 1 minute.
unplug the power to the router and plug it back in.
Wait for a minute and try to set up the router manually.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
I keep getting an error message when i set my router up
The LAN cable maybe faulty, try a different LAN cable.
1helpful
Everytime i set up my router it says "your ethernet cable does not appear to be connected properly. Error 321: Ethernet Cable not connected" now i have tried setting this up multiple times but i keep...
there is a program on your computer that shouldnt be there thats preventing it from working..go to start then control panel then clink on maintenance+system then click on device manager and any program in the list in yellow triangles you uninstall.
Router Issues
Reset it.. Then plug into a LAN Port. Just http into it. To see if it works.. Let me know how it turns out.. www.ywaitsystemservices.com
3helpful
Linksys WRT160N will not finish installing. On the 4th step it says your ethernet cable does not appear to be connected properly. Error 321. I don't really think its the ethernet cables because i tried 2...
error 321 or 322shows that the cable is not connected to the router and the computer.
That is actually a bug in the CD. Even if the cable is connected it shows that it is not connected.
You can set up the router manually, without the CD.
Click Here for step by step solution
1helpful
Error 321 'ethernet not connected' on LINKSYS WRT54GS
Dont go with the error , i came across such instances on a few occasions while users were installing it from CD . (Sounds lamme?right)
Try doing the set up manually , by accessing the web Gui of router .
***FOLLOW THIS********
The GS comes set to 192.168.1.1 as its factory default and with its built-in DHCP server enabled. So all you'll need to do is plug in a client that's set to obtain its IP address information automatically, maybe do a DHCP release / renew (or reboot your client computer), and enter the default password into the login box that pops up. If all goes well, you'll get the main Setup screen.
The Internet Configuration Type selector automatically refreshes the browser screen to present settings appropriate to the choices of Automatic Configuration - DHCP, Static IP, PPPoE, PPTP and Heartbeat Signal (for Australian users) Internet connection types.
MAC address cloning gets its own page in the Setup section, as does setting up either dynamic DNS service from dynDNS.org or TZO, setting up static routes or disabling NAT features and converting the GS to a non-NAT router.
The interface is generally quick, with quick mini-reboots needed to get the changes you make on each page to take. Multiple admin logins are allowed, with no warning given when two or more admins log on. Once you're logged in, there's no idle timeout, and you just need to remember to quit your browser when you're done, because there's no logout button.
Enabling Remote Management for the first time still pops up a message telling you to change the router's default password and you can now enable secure (HTTPS) admin access. You can also change the default remote admin port from 8080, but can't restrict access by IP address or domain. Also of note is that you can't reboot the GS from the Admin interface.
Let me know if you require any more assistance.
321 error
Still not connected
vhevk your ethernet cable wire.
if u connect router to swithc then use straight cable.
if u use router to computer use cross cable.
Start up
First, see if your firewall is not blocking the connection.
If it is, add the connection as a "safe" or "authorized". It depends on the software.
Also, check if your IP address is set properly.
Linksys WRT54G2 Wireless Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
