Outside temperature started reading 70 degrees when it was actually 14. Replaced batteries in both transmitter and receiver and get no reading at all.
SOURCE: outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
SOURCE: changed batteries
Also,
SOURCE: my clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
SOURCE: We replaced the batteries on our SIO SCAN temp
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
SOURCE: Transmitter seems to have stopped working.
Have you tried holding the unit in your hand either closer or farther away from the sender while the wheel is turning to see if it picks up the signal? It needs line of sight to the sender and some units actually specify a minimum distance as well as a maximum one. On the sender it may have an arrow indicating which direction the computer should be located. Believe it or not, I have seen them work better when the sender is pointing 180 degrees opposite the prescribed orientation. You should be able to detect this with the computer in your hand. Move it around the sender to find the 'sweet' spot and direction, then see if you can manage to mount it on the bike so it will keep working.
