SOURCE: GE Profile XL44 range
I think it's the ignitor. Ours has been doing a very slow lighting for quite a while. I found if I did a cleaning cycle it seems to work a little better... otherwise a new ignitor ( Ours is gas )... now it is flashing the probe and bake lights alternately and will not turn the oven on at all.... not so impressed at this point.....
SOURCE: My ge gas range will not heat up
Inspect the ignitor for a crack or break in the continuity of a ceramic ignitor. If you can't visually discern a failure, then a multi-meter is need to check for resistance through the ignitor.
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
SOURCE: GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
SOURCE: GE PROFILE JBP79 OVEN RANGE -
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Dear Friend,
I had the same problem and the first step you should take is to replace the bake ignitor, you most likely to have a weak ignitor. If this doesn´t solve your problem, than your gas valve is failing. Despite the broiler is ok, the gas valve has independent channels for bake and broiler, so it´s possible for one to fail and the other is good. But i believe that changing nthe ignitor will solve it.
Zanes
