Question about Coby TFDVD5000 Portable DVD Player
I also consulted the manual and it said moisture could have built up inside, but I left it open overnight and that didn't work.
SOURCE: coby tf-dvd7100....it only plays half the discs :S
the cable from the laser to the ciruit board is not making contact
Posted on Oct 03, 2007
SOURCE: Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Posted on Aug 22, 2008
SOURCE: disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Posted on Jan 15, 2009
SOURCE: dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
Posted on May 02, 2009
SOURCE: Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Posted on Jul 28, 2009
