Yamaha RX-V773 Logo
Question about Yamaha RX-V773
Audio skipping using arc
The audio skipping only occurs on a few channels while the other channels work fine. It does not skip when playing music.
3 Related Answers
Anonymous
  • 236 Answers
SOURCE: Center Channel Audio
Pleae try using the usual analog (stereo connecion) then set to Theater of Dolby surrond and see if you get a center dialogue. If you are using a dsicrete conection from your DVD player to amplifier then you must be having an audio setting with your DVD to get the center audio to work. otherwise if you are already using steroa conections only from your DVD player then you just check your DSP settings set to movie... like theater, cinema dolby prologic...etc. that is where you will only get the center sound to work.
Posted on May 14, 2008
Anonymous
SOURCE: Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
i have no sound when trying to watch a dvd through my rxv2700. the dvd player is an insigna blue rya player. It worked at first but not now
Posted on Jun 20, 2009
Lanijo58
Lani Tuggle
  • 73 Answers
SOURCE: audio skips
You can get a blu-ray clean lens kit. Just as with other dvd players, or even a long time ago VHS tapes, those heads have to be cleaned, but with dvd's it is the lens. It gives you a disk and instructions how to clean your lens.
Posted on Jul 08, 2009
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
www.hivmr.com/db/k37cmjfzkk71s913ksf3j7xfxsz3zc37
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
2helpful
Audio/Music skip sounds every few seconds at random constantly
Hello my friend,what program are you using and what type of music?
First uninstall all drivers and install the latest one.Second check your CPU activity when you are playing music(from task manager ctrl+alt+del),if its too high its a problem.If you are using different music from .mp3 like .ogg or something "not common" you must install the latest codecs.I'm waiting for your reply.
When I play a new DVD on my PlayStation 2, it pixilates and skips in spots (if I rewind a bit, the skipping doesn't necessarily occur again in the same spot). But when I play that same DVD in another...
this is usually caused by minor scratches on the disk, the playstations dvd reader is not as sofisticated as a normal DVD player, so those minor scratches may causes skipping.
Sound skips in and out at the beginning only
Try updating/re-installing your audio drivers from the laptop website, or from manufaqcturer's website. Also, update your Chipset drivers.
Hope that helps
Tim
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
2answers
3answers
NaNO 2G Skips music Mp3 Sometimes Stops
In a mater in fact it could be the mp3 the mp3 was copy right protected so it skips and doesn?t let you listen to them.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
