SOURCE: Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
SOURCE: Remote Codes
I found the code...
In the remote codes guide, the Cyberhome DVD player is listed under "Portable DVD"...the code is 2083...worked for me, enjoy.
SOURCE: Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
Marlin P Jones & Assoc. Inc.. has a 5V 2.2A /12V 1.5A cord power supply that will fit into the space where the original power supply was! Lists for $6.95 but online price was $2.95. Works great! Connect 12V supply to the yellow lead and the 5V to the red lead of the output connector, black is ground, common to both supplies. Use QC terminals to the power cord input terminals, remove the cable clamp and the power supply will nestle beautifully in the space without need for support. (Remove the old circuit board plastic (3) and rear brass standoffs and use the front brass standoff for the output cable shield ground connection. (Part No. is 15955-PS) I bought two because I have a 2nd Cyberhome CD-DVD 300 which hasn't crapped out yet.
SOURCE: Reset Cyberhome CH-DVD 300
Dear friend,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
SOURCE: cyberhome dvd ch dvd 300 changed ntsc to pal by accident
I have done it! All I did was take the yellow video cord and plug it in those progressive scan plug in until I could see a blurry screen enough to be able to see to do a reset, which is under system and did a factory reset. I DID IT AND DAMN PROUD OF IT SINCE THE EXPERTS DIDN'T EVEN KNOW IT!!!!@ Jennifer pc, fl
