Question about Suzuki Motor, Power Trim, DF60-70 98-00, DT65-75 95-97, DT85 95-00, DT115-140 96-01
Flashing light oil - Suzuki Motor, Power Trim, DF60-70 98-00, DT65-75 95-97, DT85 95-00, DT115-140 96-01
Posted by 131bounty on
  • 131bounty
    131bounty Feb 02, 2014
    Hi 131bounty , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? The oil light on the dash is flashing. Outboard is showing oil in it. Is it saying the oil needs changing?
joanneallen
    New Friend:
NO THE OIL IS OK , THERE IS NO FLASHING LIGHTS
Posted on Feb 06, 2014
2006 vector get flashing oil light twice then shuts down
Maybe its trying to tell you something. Low oil or no oil flow, try replacing level sensor.
Feb 15, 2016 | Yamaha 2006 RS Vector GT
Hi I have 2 peugeot speedfight 2, on one of them the oil light was flashing I filled it up but didn't stop flashing
Low oil is indicated by a steady red light (not flashing) so I guess the oil level is not the problem.
Start off by just turning the ignition on and don't start the engine. You should only have the usual power lights and the oil light should be steady as no oil is being recirculated. If it flashes at this point, it is nothing to do with the oil pressure and points to an electrical issue elsewhere. If it is steady then start the engine and let it tick over. As you know, the red light should go out or at worst glow dimly until you rev the engine and that makes it go out as the oil pressure increases. If it starts flashing now I would suspect a relay somewhere clicking in and out and lighting the bulb. It is possible the immobiliser is playing up, especially if the battery has been disconnected, not enough of a problem to stop the engine from starting but enough to throw up an error somewhere.
Dec 05, 2015 | Peugeot Motorcycles
Various lights on dashboard are flashing. Help please?
Did you check the oil now is it basically full? Sounds like traction control but def check oil
Dec 10, 2013 | 2004 Nissan Murano
Check engine oil light flashes after oil change
Do you mean oil change warning light or oil pressure warning light?
Feb 04, 2013 | 1999 Volkswagen Jetta
A4 automatic flashing oil light
flashing oil light means there is low oil pressure,and is it thick white smoke and smell sweet. white smoke is a blown head gasket
Oct 30, 2012 | 1992 Honda Accord
Red oil light flashing, oil change no problem but light still flashing noise coming from tappets are they related I have a problem on my vw jetta ? flashing light on my dash
Yes it is related, don't drive it. First thing you should do is install a new oil filter even if it isn't time for an oil change.
May 31, 2009 | 2000 Volkswagen Golf
Suzuki Motor, Power Trim, DF60-70 98-00, DT65-75 95-97, DT85 95-00, DT115-140 96-01 Logo
90 people viewed this question
Top Suzuki Boating Experts
Marvin
Marvin
jws1013
Andrew Taylor
Andrew Taylor
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
