Question about Integra DTR-5.1 Receiver
Integra receiver 40.4 wont play ipod again
The receiver did play both ipods here at the house. then it just stopped after turning receiver off then disconnecting the ipod.
Posted by mollio64 on
Jerome Minks
  • 3,103 Answers
Is it set properly for that input? does it play on the tuner setting? check the connecting cable for breaks..
Posted on Feb 02, 2014
Will this receiver accomodate an iPod player? Thanks, Byron Nimocks
It may not take the iPod directly if it doesn't have a dock built in, but you can always connect the iPod to an available input with a suitable cable. You'll need a cable with a plug to fit the iPod headphone jack (a 1/8-inch stereo plug) at one end, and probably RCA plugs at the receiver end. Radio Shack sells one so you can see what you're looking for. If you have an iPod dock, they often have audio output jacks for connecting to your receiver. You may need a cable with RCA plugs on both ends.
Aug 07, 2011 | Integra DTR-5.1 Receiver
Playing ipod on kenwood
This happened to me. What worked was turning off the ipod (not stand by mode). Turn it back on and plug it in, it should work.
Mar 06, 2010 | Kenwood KDC-MP235 CD Player
Ipod player wont charge ipod
I probably have the same type charger / player that I also purchased from Wal Mart. If it plays your ipod it should also charge it. Make sure the lock button on the ipod is unlocked and it's turned off. If that does not work keep it unlocked and leave it on. On systems like we have that are not iHomes they sometimes have trouble figuring out what brand they need to charge.
Aug 15, 2009 | Apple iPod nano MP3 Player
IPod nano 3g video problem
I believe that something is wrong with the video file you are playing.
remove it from your ipod and try reloading it again.
it sounds like maybe a format problem or just a damaged file.
Apr 07, 2009 | Apple iPod nano 3rd Generation
Ipod wont play and games are gone
Try reseting the ipod.. Follow the steps and let me know the status
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 15, 2009 | Apple iPod nano
Usb/ipod-no sound
Sounds stupid but did you turn up volume on ipod?
Aug 04, 2008 | Car Audio & Video
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
Jun 27, 2008 | Apple iPod nano 3rd Generation
The new ipod nano
depending on when you got it, i think there is a 30 day warranty but phone the store you purchased it at to make sure.
Ipod wont work
The problem is "ipod dock receiver connector"(connector is fuck), move forward and backwards the ipod just point the ipod can play the songs..
try you!
Dec 25, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Ipod player wont work
try this link: http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm
Sep 05, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Integra DTR-5.1 Receiver Logo
73 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
