Question about HP DeskJet 450Ci InkJet Printer
Colour??? Hi there. I have a HP deskjet 450. Now and then I want to only Print in black and with no colour. How do I setup my printer so that it doesnt print with colour???
Posted by Martinp13 on
Bruce Eichhorst
    Scholar:
  • 74 Answers
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Posted on Nov 17, 2007
Why won't my HP 930c print colour when properties set to colour?
Check in printer properties., mught be you selected as print in gray scale or black & white., there select print in color mode..
Apr 29, 2015 | HP DeskJet 930c InkJet Printer
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
Im having HP Deskjet 6943, I have install black and colour catridge. I print test page its coming ok. But when i try to print colour in MS Word, Excel, Powerpoint i not getting colour, what could be the...
please printer driver setting .. give a print ...select your printer and go to printing preference then go to color tab check for any setting like print in color in gray and print in color ....... select print print in color ......and try ....
Dec 29, 2009 | HP Deskjet 6940 InkJet Printer
HP deskjet 3420 won't print in black.
It's probably because the colour cartridge has run out, it needs a colour cartridge aswell to print black.
Aug 04, 2009 | HP Office Equipment & Supplies
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
My HP 1220C cant print in colour
check printing preference on color tab.
Feb 27, 2009 | HP DeskJet 1220c InkJet Printer
HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Prints only black
you must have turned your printer to "print in black mode only" by mistake.change the settings to "print in colour" in printer properties.
Aug 16, 2008 | HP DeskJet 3740 InkJet Printer
Hp Deskjet 3650 will not print colour
Are you sure the color cartridge is in properly and you removed all of the tape?
Feb 13, 2007 | HP DeskJet 3650 InkJet Printer
HP DeskJet 450Ci InkJet Printer Logo
261 people viewed this question
Ekse
Thomas F. Schneider
