Question about Crosley Washing Machines
How to clean screen water barely running in
Need to clean the screen water barely running in crosley CAW9244BW0
Posted by Pat Sterling on
Dean Dahle
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Pull hose off and use a small screw driver to pull screen out and clean then put back in
Posted on Jun 10, 2014
Washer will not come on, I have checked the power supply and its good. Is there a way to reset electronics besides unplugging?
Are you saying that the lights are no coming on and there is no action at all? If you have no power at all you will no be able to perform diagnostics. You can look and see if the control board is receiving power by checking the L.E.D. light on the board. To access the board you will remove the screws going across the back of the console and then with a putty knife depress the clip on either end of the console from the front and tip it toward you. Please be super careful because there is electricity in this area. We don't want you to be come damaged with servicing your machine. If you need further assistant I am here to help.
Feb 05, 2016 | Crosley Washing Machines
Why don't cold water won't run into washer?
bad inlet valve maybe? try changing the hot and cold hoses opposite to each other and see what happnes? sometimes u can just clean the water inlet valve screens where the hoses connect? hardwater can plug a line quickly
Aug 10, 2014 | Crosley Washing Machines
I have a crosley cw5500w top load washer, it is filling very slowly despite adequate water pressure. Is there an inline filter that could be clogged?
Yes their are inlet filter screens where the fill hoses hook up to the washer if you shut off the water at the wall and remove the hoses at the unit and look and you will see them carefully pop them out and clean,,,And you will be back in operation
Sep 16, 2010 | Crosley CW5000 Front Load Washer
Hi, My refrigerator isn't getting cold. The freezer is working ok but the bottom refrigerator is set to 7 (coldest) and is barely getting cold. What could this be? Is it expensive to repair?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Crosley WCK05W Compact Refrigerator
Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
When washing machine goes to rinse cycle, water barely comes in
I am going to guess you run a warm wash, and cold rinse. This sounds like the screen on the cold water inlet is clogged. Shut the water off and remove the hose at the back of the machine. Look in the water inlet and see if the screen is clogged. If so, carefully scrape it as clean as you can. Use a straw and blow into it to help clear it out. Replace the hose and try it. It does not need to be perfectly clean, but at least half way opened will suffice.
Jan 01, 2010 | Kenmore Washing Machines
Model CR66, comes on full volume, tried cleaning volume control, no change. ideas?
Crosley Model CR66 does not come on. It appears the transformer is blown out. anyone know the correct output voltage of the transformer? barely a year old.
Dec 06, 2009 | Crosley Jukebox CD Player with AM/FM Tuner
Water barely coming out? Assuming there is a clog in the washer
There is a screen at the water inlet valve where the water supply hoses are connected. Look in the end of the hoses.
Sep 16, 2009 | Washing Machines
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Need replacement freezer door for model Crosley WCK05W
are u sure thats the right model # ..can't bring nothing up on that model # Did u get it off a tag that said model#?
Sep 27, 2007 | Crosley WCK05W Compact Refrigerator
Washing Machines Logo
Top Crosley Washing Machines Experts
peter gittos
peter gittos
Michael Thomas
Michael Thomas
jdthefixer
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
