Question about Native Instruments Traktor Kontrol S4
No sound coming through headphones traktor s4
Im trying to listen to a song before it plays out loud using the cue button located right above the sound faders, however, no sound comes out of my headphones. I've tried switching the monitor and master controls but still nothing.
Posted by Dylan Toporek on
Ilija Dugonjic
    New Friend:
  • 3 Answers
Check your audio setting in traktor, if master is on 12 cue should be on 23 or oposite
Posted on Nov 12, 2016
lawrence fernandes
    New Friend:
Check you cue level ... it must be at 10oclock position
Posted on Apr 23, 2014
My gemini cdmp 6000 cue button is stuck it will not come out of cue. i need to hold cue button down in order for it to play
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Jul 14, 2015 | Gemini Sound Products Gemini Cdmp-6000...
Right fader knob doesn't do nothing. No sound come out from my right speaker when I turn the right knob up
PV series mixers from peavey suffer from horrible sliders pots quality, so be prepared to change that pot, it is pretty easy to change, real difficult comes out when you are trying to reach it, let me know a bit further to help you out troubleshoot accurately the issue.
Jan 18, 2013 | Peavey Pv 20 USB 20 Channel Mixing Board...
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
Monitor Cue problem
If you don't have the manual it is here:http://www.behringer.de/EN/downloads/pdf/DJX700_P0165_M_EN.pdf Have a look at page 4 under Monitor, mode switch and mix control. You might be having problems with them.
Feb 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Yamaha pt300 keyboard. only make loud humming sound. Keys register on monitor when touchedas do change in song etc...but no sound other than humming.
If the unit uses a wall transformer, make sure you have the right unit.
The Yamaha correct ones are branded Yamaha. Use of the wrong one can damage keybooard or be inoperative.
The PT300 did not come up as a valid keyboard. Suspect the number is either YPT-300 or a P-300..
Sep 27, 2009 | Yamaha Music
How to use Audioline Pro DJ Multimedia Mixer M Dex 3.0
I have been recently using this Cd Dj deck at parties and have some general knowledge of the product, it has alot of potential. Is there anything in particular that you need help with? Or is it the general concept of using them.
Currently, i don't think there are that many websites that explain how to use the Cd decks, however i can provide you with some basic information. Most of the information here could be worked out by trial & error.
- Pitch control on the right of each cd deck can be slid up ( slows it down %) and slid down (speeding the track up %) i think the pitch control has a range of either +-10% or +-16%.
- Cue button, has the potential for Cue'ing or setting up the cd to instantly jump to the "cue'd" point with the press of this CUE button. This is done by either pressing play/pause button and rotating the jog wheel to a point of time in the track which automatically sets the cue point OR holding down the >> or << search button to find a spot within the track at a greater speed.
-Vinyl mode. Pressing this button will set the deck to the "vinyl mode" to simulate scratching or even backspins. pressing this button again will change the mode back.
- the Crossfader (or 'X' fader) button will select the left cd track if the x fader is all the way to the left and the right track if the x fader is all the way to right. having the X fader in the middle will play both tracks together.
- Low, Mid, High. These nobs on the middle section of the deck change the individual track by which it is corresponds. (Left side = left cd track, and vica versa) Low refers to the Bass of a track which can be essential for mixing two tracks and elminating excess bass noise. Mid refers to the drumming and even synth of a track, and changing this can result in some cool sounding effects. High refers to the 'high' frequencies of the track playing, such as snares, hi hats and possibly vocals. All these controls are crucial to understand in order to mix 2 songs together successfully. It's good to get a chance to muck around with these cointrols. The middle of each control resets the setting to normal or default.
- Channel fader. the two controls that slide up & down on both sides of the mixer on the deck. This is also referred to the volume setting. Useful for mixing seamlessly one track into another.
- Gain. This control at the top of the mixer refers to the volume level or 'gain' of the cd track that it corresponds to.
- Jog wheel. Serves 3 purposes. firstly it can be used whilst a song is playing to temporarily speed up or slow down the track to match with the song on the opposite side. secondly, whilst holding down the 'search' button, operates as a control to quickly find a spot in a song. and lastly when selecting "vinyl" mode, can simulate the reaction of a vinyl turntable. The scatch function, and backspin effect.
- The pitch button, is just another control to speed up or slow down a song temporarily whilst holding down the '+' or '-' button.
- Reverse button, for a certain amount of time will play the song on the left or right in reverse.
- Time. this button is essential to change the time selection on the cd deck, to either "Time elapsed", "Time remaining" and "total time remaining on the cd".
- the "tap" button, allows the user to physically "tap" the button in time with the song's beat, which calculates the Beats per Minute (Bpm) of that song. which is essential to work out the bpm of 1 track to mix the speed with that of the opposite deck.
- Cd/usb/sd, changes the mode of system reading. from CD to USB or SD card.
I really hope this general guide to using the Audioline ProDJ MDex3 has helped!
Peace. Marc.
Apr 03, 2009 | Music
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Native Instruments Traktor Kontrol S4 Logo
175 people viewed this question
Top Native Instruments Music Experts
Marvin
Marvin
Are you a Native Instruments Music Expert? Answer questions, earn points and help others
