Canon FAX L-120 Plain Paper Laser Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display showing Remove orig from ADF
We,re trying to send fax but display is showing Remove orig from ADF any ideas
Anonymous
Level 2:
  • Expert 106 Answers
  • Posted on Jun 05, 2009
Anonymous
Expert
Level 2:
Answers
106
Questions
Helped
48613
Points
386
Remove original from auto document feeder... it thinks that there is a paper jam... check into that.
How do fax with Setting Up the Hardware for Faxing on samsung xpress c460fw printer
Dear connect the telephone line to the socket marked as LINE at back side of the printer,also you may connect an extension phone to the socket marked as EXT.
Put the document face down ward at platen glass and face upward in the ADF.
Select the key marked as FAX(if there any near display ) press OHD/SPK key get the dial tone, dial the fax no. get the RX. tone press START. Display will show sending.
Also it can be scanned and send from memory by loading the document and dial the fax no. press START.
Your ID and fax no. can be stored at FAX setup menu.
Thanks.
WHEN I SEND FAX THER IS NO ANSWER
Dear
Connect a telephone set to the extension of the fax machine port where it is marked as EXT.
put the document on ADF or platen glass.
press OHD/Spk Key (get the dial tone)
Dial the required fax no.(get the ring back tone-then RX tone(some kind of beep tone)
Press START.
Display shows sending (if not display may shows 1-sending,2-receiving, then press 1. for sending)
Take the hand set of the telephone hear the noise continuous.
If there is no noise, There some problem with hardware, misht be LIU card, main PBA or both. And you need the assistance of a trained service engineer.
Thanks.
How do I set up on my printer to connect fax
Dear
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Thanks,.
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Receive has replaced send on my on teleface 2820
Make sure the document is inserted 'deep' enough into the ADF. Make sure after inserting the document, the display shows 'key in the destination number & press start'.
2answers
I have a Canon L100 machine that is displaying the message REMOVE ORIG. IN ADF>. However there is no document jam. I have followed the instructions for removing a jam and have also turned the machine...
open the adf cover you should find a little plastic lever which is a paper sensor it is possible that it is stuck in a open position.be sure that the lever can swing freely
1helpful
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
2answers
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
old marine
old marine
ZJ Limited
ZJ Limited
