Sylvania SMP2012SL 2GB MP3 Player Logo
l
leslie beltran Posted on Feb 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove music off mp3
How do i delete all my music on an iMac? my music doesn't show up when i clack inn the device but it is on the mp3
Mark Anthony Monzon
Level 2:
  • Expert 302 Answers
  • Posted on May 27, 2014
Mark Anthony Monzon
Expert
Level 2:
Answers
302
Questions
0
Helped
48765
Points
946
Just go to music folder and there's an itunes folder there, look for the music folder and the songs will be there
In my mp4 it shows that i have 376 songs and when i try to see it on the computer it doesn't show any of the songs.
Hi owaisdw3...
Try finding your songs this way:
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
If you want to delete the music the do the following:
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
This is a FREE answer, Please take time to rate me
How to upload music files from sansa clip to IMAC
Plug the device to pc, it will appear icon "sansa clip..." or removable disk, double clip on that >> double on Music folder >> drag & drop songs from Music to pc.
Good luck
Need to remove downled music from coby mp3 player, how?
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
Thank you
Belbwa
1helpful
2answers
Removing stored music
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Cant view music list
do you put all your music on ur iriver thru the program or direction onto the "removable device"?
2answers
How do I delete songs from my M202E?
open windows explorer, if it shows up as a drive letter you should be able to add or delete files same as from any other drive. This is assuming it is a usb storage device.
"MTP DB Mismatch Format?"
The Insignia NS-DA2G needs to be placed in File & Folder mode, and you'll need to have your mac show you all files on the device. Macs will create a smaller file that starts with "._" that contain very little information, but can cause problems with Windows based or Windows preferred devices. These files are not ignored by the PC or certain Windows optomized devices. You should erase these files for the unit to perform normally.
If you are unable to delete these files, you can re-format the device to FAT-32 and that will erase all information on the device. You shouls also hit the reset button (located next to the "HOLD" switch) for about 5-10 seconds to clear the internal settings.
I cant even delete my music or put new music on...
Instead of deleting the songs you may need to format.
If you haven't tryed this follow these simple steps.
To format your device first click on "Start" then click on "My Computer" now look for your mp3 player, if it hasn't been change the names usually called "Removable Disk", once you've found that right-click on it then click on "Format".
Now you've formatted put songs on then try your mp3 player to see if the problems be fixed.
Good luck. Hope my solution was helpful.
Top Sylvania Audio Players & Recorders Experts
Aron
 Grubhead
Grubhead
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
