SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
SOURCE: Print continuously
I know late, but we just had the same issue and it seems the sensors on the outside and inside needed to be cleaned. once that happenned, labels are not printing out continuously.
SOURCE: Label Printing stuck in queues
Yes that is correct the Z4M is not supported any longer as they have reached End Of Life although parts are still available. The problem will be because the printer hasn't got enough memory, the Z4M uses flash RAM installed on the Main Logic Board. These might not be readilly available, another thing to use would be a Print Buffer. You should still be able to get them. The idea is to control the amount of data that is flowing to the printer, if the internal buffer fills up it will corrupt the data and a reboot is required.
SOURCE: Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
SOURCE: I am having problems with Zebra printer MDL#ZM400
Try entering the Menu system and exiting, whilst exiting and instead of saving permanent, cycle around to load defaults. once you have done that make sure the settings are as you need such as Thermal Transfer etc and save permanent. You won't have a problem after that. If you do I would be checking the page setup in the software to make sure it fits the lables.
