The blue powerlight and the 2 red and blue battery lights keep flashing and Ii have tried to shut off and turn on but they continue to flash.
SOURCE: Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
SOURCE: the orange light or the battery keeps flashing
If you have replaced the battery then it is either the charger or the motherboard which is at fault. Be sure that the input jack for the charger on the computer is not loose. Try using another charger to check which is at fault.
SOURCE: Acer aspire one does not boot up. Battery light
You have a motherboard failure...and will need to replace your motherboard. This is a common issue with Acer. Sorry to be the bearer of bad news.
