use the common sense, and logically, fix it. God bless you
Microwave Runs, Heats, but turntable does not move This is a
fairly easy one. First, make sure the turntable coupler under the glass
dish is not broken. Second, on the control board, find the turntable
relay and test for voltage. Some turntable motors are 24 volts DC, so
make sure your testing the correct voltage. If no voltage from the
control board, then replace the control board. Otherwise head towards
the turntable motor.
On OTR models, you can get to the motor by
un-screwing the bottom panel on the microwave. On countertop models,
there will either be a knockout or screw on access panel. Check for
voltage at the motor. If no voltage, check the wiring back towards the
control. If voltage, then replace the turntable motor. The component
list below also shows how to test a turntable motor.
