Question about TP-LINK Computers & Internet
Tp-link system light off
Tp-link router tl-mr3420 v2 Just rebooted from system tools now router doest work. Just power light on but other light off. when first pluging in all light flashes one and just power light on .. Can i fix it ?
Posted by illidan74770 on
baha abu soude
    Habit-Forming:
    New Friend:
  • 33 Answers
I think , you should replace your router , electricity problem
Posted on Feb 03, 2014
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: I have a TP-Link router ,it's working fine but i
Page: 26 to 35
http://www.tp-link.com/english/soft/2007731040544.pdf
Hope it helps!
Posted on Apr 13, 2009
abdul latheef
  • 145 Answers
SOURCE: Have D-Link G604T router/modem and want to connect
Dear,
I think this will help you http://www.tp-link.com/support/showfaq.asp?id=151
Posted on Oct 17, 2009
govinda123
Prashant M
  • 2277 Answers
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Posted on Feb 01, 2010
clare su
SOURCE: After using TP-Link TL-R480t+ Router Video streaming from internet at sites such as youtube does not work at all
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
Posted on Nov 23, 2011
Filip Eastman
  • 477 Answers
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Posted on Mar 08, 2012
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
Bsnl adsl modem configure with TL-MR3420 router!
TP-Link Router not working, want to setup TP-Link router, have troubleshooting issues. No need to worry we are here to provide you the best solution according to your requirements of router issue. You just need to dial TP-Link Router Helpline Number avail at toll-free number 1-833-284-3444. Our tech support team includes executives who are professional and know each & every solution which may arise at the time of accessing.
The wireless network is unstable via my wireless router/modem router
Some time router is not still connected and working that time users do follow given instruction and make the trouble-free router.
Locate wireless clients in a reasonable distance.
Get away from obstacles.
Reduce the number of wireless clients.
Decline interference from other wireless equipment.
Optimize the router's position.
Change some settings on the router.
Test the WIFI device.
Get technical service for your problem which is not understanding how to solve the technical issue, our technical expertise is available for 24*7 and they are ready for pick up the call when called by the customer. If wants to more technical service visit our TP-Link Router Service websites.
https://servicenumber.org/tp-link-router-customer-service.html
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
HOW TO SET UP TL-MR3420 USING GLOBE POSTPAID CONNECTION
follow these steps:
1- connect your pc with router
2- open browser.
3- type the ip address of router : 192.168.0.1
4- press on quick setup.
5- choose the first option 3g/4g
6- press next
7-set location , AT&A , username , password
8- press next
9- finish
make sure your wireless usb was connected with router in the area range of wireless of your isp .
Nov 27, 2013 | TP-LINK TL-MR3420 Wireless Router
Tp-link tl-wr841n system light keeps on flashing, how do I fix it?
system light must flashing every second or one second . that is mean the system work correctely . but if the light was flashing rapidly , i think there is problem with system .
reset router , if the light keeps flashing , change the router
Aug 21, 2013 | TP-LINK TL-WR642G Router
Bsnl broadband configure
the router without any Modem WITH internet is useful. You must have Moden with BSNL broaband. Remember the router the only function is amply the signal for internet for use in wireless.
God bless you
Jul 11, 2013 | TP-LINK TL-MR3420 Wireless Router
TL-MR3420
insert your 3G Card adapter to the USB port and thenuse your PC come to http://192.168.1.1 log in to the admin with name admin, password admin .
Open the operating status, it will show being identified, waiting about 20s it will done. else if it can't be recognized. You need to set the BIN file by you self, you can download the file from www.tp-link.com
Then set it step by step as it show
May 02, 2013 | ASI Tp-link Tl-mr3420 300mbps Wireless N...
TP-LINK TL-MR3020 need DUC or not i connect only hikvision dvr
Remotely would imply a different building or location. What exactly are you trying to accomplish? Do you mean hook it up in one room and record and watch shows in another? Or over the internet? Give more info.
Feb 02, 2013 | TP-LINK TL-MR3420 Wireless Router
I csl modem can not be used due to wrong settings
Push and hold the reset button for 30 seconds or so, release. A user manual can be found here: http://www.tp-link.com/us/products/details/?model=TL-MR3420#down
Jan 24, 2013 | TP-LINK TL-MR3420 Wireless Router
Cannot access my tp link TL-WA601G 108M Wireless Access Point
Use the Factory Default Reset button: First, turn off the AP's power. Second, press and hold the default Reset button then turn on the AP's power, until the system LED lights up (about 3 seconds). Last, release the reset button and wait for the AP to reboot.
Reset the factory defaults.
Here is your user manual:
http://www.tp-link.com/english/soft/20091515618.pdf
Default username and password is admin for both
May 20, 2012 | TP-LINK Computers & Internet
Computers & Internet Logo
626 people viewed this question
Top TP-LINK Computers & Internet Experts
Zaid Anarwala
Zaid Anarwala
Lawrence Oravetz
Vernon Taylor
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
