The default credentials for your router are "blank" for username and "admin" for password. In case you have already change these, you have to reset the router (using the proper button) in order to come back to the factory settings.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards Please kindly rate this solution Stelios direct FixYa link: http://www.fixya.com/users/technical114
If you have forgotten the router's password then you have to reset the router to factory default to access the interface again. Then you can use the router's default user name and password, that is admin and admin (or username: " " (leave it blank) and password: admin (all in lower case)
You can find the default passwords on the following website;
Welcome to Fixya.For you to access your router you need to type 192.168.1.1 to he address bar of your browser and it will ask you for a username and password. The default username is "leave it blank" and the default password is admin
Open up internet explorer or your favorite browser
type in 192.168.1.1
press enter
if you did not change the user name and password, username should be left empty with nothing in the username portion and the password is "admin"
if you did change the password and forgot the router password then you must hit the reset button on the back of your router to default the router and will need to reset up your wireless security settings.
but, once you get into the linksys administration page goto the wireless security section and you will see your wireless password there.
"Limited or no conenctivity" means that the network key(security password) that you typed when connecting to the wireless network is incorrect. Try connecting the laptop to the router using an ethernet cable to check whether you can get online. Access your router's setup page to check your network key.
How to access the router's setup page :
1. Using a wired computer, pull up internet explorer or any browser.
2. On the address bar, type in 192.168.1.1 (default IP)then press enter.It will then ask you for a username and password. If you havent changed the settings, username should be left blank and the password is admin.
3. On the black bar on top of the setup page, click on the Wireless Tab. Then on the purple bar, click on Wireless Security.
4. On the Wireless Security page, you will then be able to check your network key.
1.Open the router page (192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blan)
3.On the router setup page click Wireless
4.Click Wireless Security and Select the Security mode as WEP
5.WEP encryption 64bits
6.Key1-Enter 10 digit or 10 letters password(like your telephone number) and click save settings
7.Turn off the router for 30 seconds and turn it on after that. Now your network is secured
BSNL is ADSL connection, and you will need the username and the password from BSNL to get the Router working with the Modem, make sure you have the Correct username and password from your ISP which is BSNL, that will fix your issue.
Load your internet browser page and type in 192.168.1.1 or 192.168.1.100 one or the either. The easiestway is to go by your gateway address. Type that in and your router page will load. You will need a username and password. The default is admin on both, but if you had setup it before it will be your own. Then go to the wireless tab and follow the steps.
