Kleenmaid kfl1600 front loader, Program is displayed however when start button is pressed nothing happens, water does not come on, valves test OK, door lock OK. Any ideas what to check next.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Your washer is in the
"child lock" mode, hence it won't allow any program. Press the "menu" button until you
see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following
this the menu will close and it will default to program in the display. Once you see that in the display, press the
"select" button until "CHILD LOCK :OFF" appears in the
display. Finally by pressing the
start/pause button the key symbol should disappear - confirming you have
successfully exited the child lock program.
Pl click if helped.
