SOURCE: mother board does not boot
actually tell us what and how is the beep coming and what is actual problem. is the pc starting or not or the display is coming or not Thank u Regards Anand patil Hyd
SOURCE: Continous Beeping sound
Hi neosw,
Could you provide a little more detail?
Was this a previously working set-up or is this a new build?
If this was a previously working set-up have you changed anything?
When you switch on the PC
The reason I ask these questions is because a continues beeping usually means that the BIOS is not seeing the processor, or that the power to the processor is not correct. With some BIOS manufactures it can also mean the processor clock speed is not set
correctly.
Please don't take this the wrong way but...if you provide greater detail in your question, the easier it for us to diagnose your problem, otherwise we can only make educated guesses.
I hope this has been of some help.
Regards,
Spare head 2
SOURCE: d101ggc
my motherboard Intel D101GGC has no display and no beep also i change the memory but they same problem i encountered..what are the solution i applied in this problem...
SOURCE: continuous beep
I have looked up the code you describe. It is best is you go to the site and see for yourself. I am providing a link. You also might try removing all the cards except for the video to see if anything changes.
http://www.computerhope.com/beep.htm
