Lexmark X2600 InkJet Printer Logo
A
Anonymous Posted on Feb 01, 2014
Clean rollers how do you clean the rollers
How do I fix a Canon MP460 printer that feeds multiple sheets at a time, even for a one-page document, causing a paper jam?
Assumed you have cleaned out the feeding slot and sprockets that turn the feeder wheels. Often there's some piece of paper or gunk. One option that likely applies to most printers -- from another HP online source: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00190540&cc=us&dlc=en&lc=en
  1. Look for paper that might have jammed inside the product. Use a flashlight to carefully view the areas around the rollers. Remove all traces of paper found.
  2. Wipe the rubber paper-feed rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers up carefully to clean all the way around.
  1. Look for the paper pick roller farther inside the rear access area. The paper pick roller
    IMPORTANT : The paper pick roller is a bit more difficult to reach; however, it is the most important part to clean. Make sure to clean it thoroughly. If this roller is not clean, the issue will likely continue.
  2. Clean the paper pick roller with a cotton swab moistened with distilled or bottled water. Apply a moderate amount of pressure to make sure that you remove all debris. Clean the roller thoroughly all the way around. Figure 8: Clean the paper pick roller
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/855/c01996641.gif" alt="Photo of cleaning the paper pick roller." title="Photo of cleaning the paper pick roller.">
  3. Make sure that the rollers on the rear access door or duplexer are clean and in good condition. If any are missing, stuck, or loose, replace the rear access door or duplexer with a new one. Figure 9: Rear access door rollers
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/968/c01977887.gif" alt="Graphic of the rear access door and paper rollers" title="Graphic of the rear access door and paper rollers">
  4. Allow the rollers to dry completely, and then replace the rear access door or duplexer. Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
Cannon MP 250 crayon stuck between rollers
Description
Cleaning the Paper Feed Roller - MP250 / MP270
Solution
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and remove any paper from the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Clean the Paper Feed Roller.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4. Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
If the problem is not resolved after cleaning the Paper Feed Roller, contact the service center.
NOTE:After the cleaning is completed, press the Stop / Reset button to return the LED to the copy standby mode.
My pictures are coming out with pink or purple streaks. Every time I print a picture, the streaks are in different places, all going from bottom left to top right . I have changed the ink roll and the...
Try cleaning the paint roller.
6 Care and maintenance
Cleaning the paper feed roller To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the paper feed roller clean. Inspect the roller weekly for debris particles, and clean if necessary.
IMPORTANT: Unplug the power before cleaning the paper feed roller.
spacer.gif spacer.gif spacer.gif spacer.gif 1.Unplug the AC power cord from the power outlet.
2.Remove the paper tray from the photo printer, and leave the paper tray door open.
3.Lightly moisten a lint-free cloth with water.
IMPORTANT: Do not use cotton or cotton swabs to clean the paper feed roller.
autourg00462006id1604162.jpg 4.Use the moistened cloth to gently wipe clean the surface of the paper feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
5.Allow the paper feed roller to fully dry before reconnecting the power.
Click below for the complete manual:
Kodak EasyShare Photo Printer 500 Manual
Hope this helps.
Zeppelinx12
Card are stuck in evolis perbelle 4 so we get it by hand and then we have mechanical issues
First check for your card's thickness and adjust thickness lever accordingly.
Take a soft cotton cloth soaked with Isopropyl Alcohol with minimum water content.
Clean all Rollers including one roller below the feeder.
For cleaning Rollers you can take out ribbon and press the push button on front panel.
This will move Rollers and you will be able to clean rollers easily.
Clean the rollers below ultraviolet ribbon sensor and the roller set at output hopper also.
What is the recomended maintenance for this machine
check and clean the feed rollers at paper feed with cloth and water or cleaning fluid remove drum unit and check the condition of the foil on drum for dents or marks.. clean the rollers at pressure roller and clean this off with spirits and soft cloth(rollers under the drum) empty out the master waste treay and clean off rollers here with spirits and cloth and check nozzle at air blower to the left of drum (Yellow nozzle for damage and blockage.. then check the tension of the master feed roller and clean the thermal heads with a soft cloth..remove the scanner glass and clean both sides with glass cleaner and clean off the lamp unit mirrors(take care here you dont miss align on guides)
3helpful
2answers
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
I have cannon image runner 4570 that I cleaned
The transfer roller is cleaning use to a vacuum cleaner.The black lines is caused to dirty charge corona or charge roller.Clean the charge unit.
4helpful
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
5answers
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
