Question about Radio Shack IndoorOutdoor Thermometer with Hygrometer
Thermo hygro 63-1032 - Outside temp will not read; LL.L error code. What does this mean and how do I fix it. Thank you.
Old model - can't find manual
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Radio Shack thermo hygro sensor model 63-1090 reads everything except the outside temp
I ran into this problem and note that in the manual is states for "best results" the sensor should be powered up before the station. I had the station running and it wouldn't lock even after several hours. When I powered it down and brought it back up, it saw the sensor just fine...
Jan 15, 2011 | Radio Shack IndoorOutdoor Thermometer with...
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
We have a code SC552 functional problem with copier what does this mean
if the machine is a plack and white ricoh then the new error code is for the thermistors in the fuser they are not sending the correct temp readings check the fuser for toner build up on the surfaces of the thermistors and check the thermo fuses to see if they are blown....GOOD LUCK aa>>
Jul 30, 2009 | Lanier Office Equipment & Supplies
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Mar 28, 2009 | Frigidaire Freezers
Honda Accord 94 model. Fan not kicking in.
Hi
Bridge the fan temp sensor wires, if fan works, renew temp sensor.
Good Luck !
Please give a FixYa rating if you think I have been of help, thanks !
John.
Jan 17, 2009 | 1994 Honda Accord
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Radio Shack IndoorOutdoor Thermometer with Hygrometer Logo
245 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
