Step Down Voltage Converters You can use this link to find a converter that should work. There are several other sites as well. You need to get a converter with enough wattage capacity to operate the freezer. I recommend you get one with a somewhat higher wattage rating than the freezer's wattage rating. For instance if the freezer is rated at 700 watts, I would get at least a 1000 watt converter. Good Luck !!! and Bon Voyage !
Is this a trick question? It is 20.3 cubic feet according to your question. This may be the capacity or the size of gross measurement ... you have not indicated.
Please ask the actual question you want to know ...
Sounds like the defrost termination (stops the defrost) has failed. If you are handy you can replace the termination control yourself. The question also arises why the "Fail-Safe" on the Time Clock (takes unit out of defrost if termination control failed) did not work.
i didnt got my answer
