Question about JVC RX-6018V Receiver
Rear speakers wont work - JVC RX-6018V Receiver
Rear channel speakers wont work on new stero
Not wired correctly or fader needs setting!
Mar 26, 2014 | 2005 Toyota RAV4
Rear left speaker wont work
Try swapping speakers...the rear one is probably blown out.
Dec 30, 2013 | Panasonic Audio Players & Recorders
Rear windshield wiper stopped working, 4x4 dosent
sounds like a lot of fuse's blown or the fuse box it's self has a fault
Dec 24, 2009 | 2004 GMC Envoy
My rear speakers used to work now they dont
check your fader option...if that fails, you might have loose wires or need to replace them.
Jun 01, 2009 | 2004 Chevrolet TrailBlazer
Stereo wiring for my 1997 jimmy
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck and hope this helps.
May 13, 2009 | 1997 GMC Jimmy
Rear Speaker Wont Play
This is most likely a driver issue. I would goto the creative site and use their automated updating tools.
Mar 26, 2009 | Microsoft Computers & Internet
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
Rear and Centre speakers not working
The system comes with l remote which provides controls for "Power", "Master Volume", "Bass (Subwoofer) Volume" and "Matrix Mode" . Matrix mode allows you to spread stereo sound to all speakers where your sound card may not have the ability to do so.
I find that the "Stereo Surround" setting works best as opposed to the recommended "CMSS" setting
Oct 22, 2008 | Logitech X-540 Multimedia Surround Sound...
RCA HOME THEATER SYSTEM REAR SPEAKERS NOT WORKING
cheak the mode u are in theter mode reg sterio mode wont do the back ok cheak settings dsp modes
Jan 20, 2008 | Audio Players & Recorders
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
JVC RX-6018V Receiver Logo
Top JVC Audio Players & Recorders Experts
xxxxxx xxx
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
