SOURCE: Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
SOURCE: hose attachment
Your wand is getting stuck in the hose because the hose is twisted - you need to unwind it:
1) Pull the wand up as far as you can, all the way if possible
2) Stretch the hose out and unwind it, use some babypowder on the metal part of the wand and in the future, unwind and stretch the hose out after you use it
3) If you can't get the wand all the way out, remove the canister from the front, push the button where you see the 7 vertical grooves (on the opposite side of the hook that you wind the cable around) - then pull on the hook and pull the hose up and off of the machine - stretch the hose out from the bottom and pull the wand out - now apply baby powder to the metal rod and disconnect and stretch and unwind the hose every time after you used the wand to clean.
SOURCE: I have a Dc-25 Dyson ball,The beater bar does not
check to see if the belt is broken or loose and have a technician look at the clutch to see if its burnt out.
Testimonial: "it was somethimg simple, the wheels were'nt releasing. thank you. Bruce"
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
SOURCE: Dyson DC 25 Dyson Ball animal. The bottom brush
Two things you can do.
1- Remove the brush as if you were going to change the drive belt for it.
Clean the brush as best you can and spray some WD40 on the hard rubber/plastic
pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space
between the pieces and the brush axle.
2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation.
If you find this solution helpful, I would appreciate a Thumbs Up from you.
Thank you.
Paul
