LG 37LG50 37 in. LCD HDTV Logo
Tom Rochester Posted on Feb 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Volume won't work on the remote control - LG 37LG50 37 in. LCD HDTV
Gene
Level 2:
New Friend:
  • Expert 112 Answers
  • Posted on Feb 01, 2014
Gene
Expert
Level 2:
New Friend:
Answers
112
Questions
0
Helped
20548
Points
304
Dude buy a new remote control but if you have done already then you might as well send the tv to the nearest service centre.
with thanks
The volume buttons on my remote for an amp won't work.
try a piece of alum. foil next time before you cut the buttons out---may still work with clear tape over it.
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
1helpful
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Lost the volume on new cox universal remote. Reset instructions won't work either.
This is a common problem with these remotes, just call Cox or go to the local office and have it exchanged.
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
2answers
I was trying to look for the input, and accidently locked the screen
You will need to have the remote:
Press the VOL+ on the remote control and the CH+ button on the front of the TV.
The TV will prompt you to enter a new password.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
