SOURCE: Toshiba RD 85-DT dr-2 error code
Hold the easy nav button and the number 2 down for a few seconds then
try using the remote.Hope this works for you too.
SOURCE: Every time I try to
It is confusing to many people this function, but not impossible to investigate (perhaps experiment with some of the functions). You can get a copy of the INSTALLATION GUIDE (if you don't have a copy for any reason) from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/RD-XS32SU_Inst_E.pdf
and if you don't have a copy of the original OWNER'S MANUAL, you can also download that from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/rd-xs32_om_e.pdf
(copy and paste into your browser if required - these are both FREE documents)
(Page 48 of the installation guide (not the owner's manual) tells you about IR CODE setup option using remote - read that first if you like, then try your recorder).
Hopefully this helps you a tiny bit.
SOURCE: toshiba RD-85DTSB recorder remote control
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
