Starts then stops
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
SOURCE: help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
SOURCE: Asko 3350 Dishwasher
The "F7" code means that the drain is blocked. To remove items from the drain: 1.Turn power to unit off. 2. Remove the "Coarse Filter" by squeezing the tabs together and lifting out. 3. Remove the "Fine Filter" and "Main Filter" by removing the screws around the filters and lifting them out. 4.Remove the small black adapter piece and check the sump area for debris. 5.Wash the filters out gently with hot, soapy water. DO NOT RUN THE UNIT WITHOUT THE FILTERS IN PLACE! 6.Replace the black adapter piece to its original position FIRST (Important!). 7.Replace the filters in reverse order of removal and turn the unit back on. The error code should reset and work normally. *In areas with hard-water, the filters should be removed every 8-12 months and submerged in a chemical solution (CLR or LimeAway) to remove mineral deposits. Hope this helps...
Just click below;
WHAT IS WRONG WITH YOUR DISHWASHER?
For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
SOURCE: f7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
